Sponsored by: Innova
Alpine Speakers and Amplifier Question
Old Nov 20, 2001 | 04:49 PM
weldman's Avatar
weldman
Post Alpine Speakers and Amplifier Question
I've been looking into upgrading my 23 year old 5 1/4 pioneer front speakers to go with my decent rear 6x9's.
Being partial to Alpine components, the speaker that I have found that looks good to me is the SPR-135A 5 1/4 component speaker. I don't want to put in 6 1/2, as cutting up the door looks to be required. Am I right?
Peak - 180W
RMS - 50W
Freq Response - 40hz-35Khz
As well, I am looking into adding an amp to improve sound quality and power. I've looked into the Alpine V-power MRP-F200.
Max Power - 75W x 4 (4 ohms)
RMS Power - 40W x 4 (4 ohms)@ 14.4v
- 50W x 4 (2 ohms)@ 14.4v
Are these components going to work well and produce good quality sound?
Note- I have an Alpine 7827 25W MAX cd player and the rear Sony 6x9's are 140W/40W 3 ways.
Any opinions, insights? More info needed?
Thanks,
Matt
Old Nov 21, 2001 | 12:36 PM
Jerm's Avatar
Jerm
The setup looks good to me, however I am a litle confused by your first paragraph.
Why on earth are you afraid of cutting the doors to accomodate bigger speakers?? One would thing a guy with the username "WELDman" would feel pretty comfortable making modifications to metal parts.
I would try to get the bigger speakers in there, because the active cone area in a 6.5" speaker is around 33 square inches, while a 5 1/4 inch cone only has around 21.5 square inches. You get over 50% more speaker by moving up to the 6 1/2's. Just something to think about.
Jerm
Old Nov 21, 2001 | 12:51 PM
weldman's Avatar
weldman
[updated:LAST EDITED ON 21-Nov-01 AT 02:11 PM (EST)]Good recommendation, but all is not what it seems!
The name weldman comes from the Weld Racing rims on my '78!
If I had a heated shop (will be putting these things in in the middle of December) let alone knew how to weld, I would put in the 6.5's!
Ok, so I am intrigued, what is the best way to fit the 6.5's in there, just cut the whole bigger and don't worry about recreating the recessed portion that the original 5 1/4's fit into?
Another question, when you guys have put in better door speakers in the 73-79's, have you cut up the door panel and installed the speaker grille, instead of just putting the door panel over top, which looks like it would obstruct sound quite a bit?
Matt
Edit - Crutchfield says that 6.5's are stock.....anyone agree/disagree?
Old Dec 20, 2001 | 12:43 AM
benz302's Avatar
benz302
The 6.5's fit right in the doors on my 79 bronco (might have to drill new mounting holes) . I wouldn't put 6x9's in the back though . Put some truck boxes ith 8" woofers and top firing tweeters behind the seat , you'll be much happier . Even the cheap behind the seat boxes sound better than a 6x9 .
Old Dec 20, 2001 | 12:57 AM
benz302's Avatar
benz302
also , cutting the door panel depends on how you use the truck . the slots in the door panel point towards the floor , so if if you cut the panel you will lose allot of sound quality . I didn't cut my panels because when I'am wheeling I get allot of water in the cab and the panels will keep them dry .
I also advise that you buy the ceap plastic covers that go over the inside (back) of the speakers to protect them from water .
Old Dec 20, 2001 | 01:51 PM
frankc29's Avatar
frankc29
displacement4me
Feb 10, 2009 10:17 PM
DCRB
Aerostar
Apr 10, 2008 08:00 PM
jnowlin
2004 - 2008 F150
Mar 6, 2008 02:24 PM
weldman
Nov 23, 2001 02:05 AM
weldman
Mar 25, 2001 06:09 AM
