trans comp
Old Jun 23, 2008 | 12:36 AM
crazymike's Avatar
crazymike
well i prettymuch know the pcm thats in it is completeley dead ....on that note. do the backup lights go thru the pcm or are they bases on where the shift **** is or what?
Old Jun 23, 2008 | 01:34 AM
David85's Avatar
David85
Its funny you should ask that because the backup lights never worked on my truck since I bought it. The switch was bad on the old transmisison and the wiring was wrong on the wiring harness when I installed the aftermarket setup (factory defect, it would seem). I only figured it out this afternoon.
But more to the point, the backup switch is integrated into the MLPS on the side of the transmission, so it should still work.
Old Jun 23, 2008 | 02:54 PM
crazymike's Avatar
crazymike
oh wow i almost didnt think to stop and get a wiring harness too , im betting that it might make it a little bit simpler because im betting they dont just put the old e40d connector on their computer. dangit now i have to think again! >
Old Jun 23, 2008 | 03:49 PM
David85's Avatar
David85
They make a wiring harness that is designed specially for the TCS. It is a simplified version of the OEM harness that only takes signals from the VSS, MLPS and the FILP sensor. No connection to your break lights or tachometer (less things to go wrong). The main connector to the computer is a PC style 25 pin serial port. Cost:$150
You will have to do some minor wiring, but the VSS and MLPS will plug right in as they use OEM style connectors. If you order their wiring harness, make sure you measure the dimensions of your current harness to make sure they put enough length for each of the connectors, otherwise you could cannibalize your old harness to "stretch" anything if needed.
In theory, you could also wire your own port onto your OEM harness if you have the patience for it. All connectors are wired by hand and each prong shaps into place and can be pulled for rewiring as well. All the information that you would get if you bought the system is available for free on their website, including wiring diagrams, installation, setup and tuning instructions. I would read everything on their website before making any decision.
garm59
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 16, 2014 11:36 PM
SteelHorse4x4
Jun 1, 2014 06:30 PM
freerev
Mar 16, 2014 08:22 PM
motorhead_83
Aug 28, 2003 07:49 PM
dptywrdn
Bronco II
Jan 12, 2001 06:31 AM
