first a little truck info
'99 F-250 diesel 7.3
174,000 miles
new transmission w/ 5,000 miles on it
regular oil and fuel filter changes
6 month old alternator and batteries
mods:
4" exhaust
superchip programmer
air intake
problems:
battery light stays on when ignition off but off when running
rough idle like its missing
white smoke at start up even when engine is warm (stays smoking at idle)
11 mpg in city
13 mpg on hwy running 65-70 mph
lack of power
boost max= 18lbs.
trans temps. 190 on hwy 195 in city (ordered trucool trans cooler)
egts= 700-800* on hwy at 70mph
yesterday a tapping sound on drivers side after 2andhalf hour trip then quit about an hourand half on the way back
codes:
p0603
forget code but exhauts back pressure sensor circut(going to replace tube and sensor)
I cannot help with much of this but the low mpg, white smoke & lack of power may be a boost leak. At least aggrevating things. Check all six rubber boots as a starting point. Good luck
What kind of air intake do you have? Does the truck use oil? How long does the battery light stay on when the key is off? Is it on permanently, or does it go off after a couple of minutes?
I like Jay's idea about checking the boots to make sure they're tight. Have you considered cleaning the EBP tube? Some of the 99's had problems with small leaks in the on the drivers side that would drip on the back of the fuse panel. That might explain your battery light issue. Next time it rains you might pull the fuse panel out and see if there's any signs of moisture there.
[quote=F350-6;6268091]What kind of air intake do you have? Does the truck use oil? How long does the battery light stay on when the key is off? Is it on permanently, or does it go off after a couple of minutes?
k&n cold air intake system
the truck doesnt burn oil
the battery light is always on when the ignition is off
the smoke out the exhaust smells like lighter fluid (first thing that came to mind when i smelt it)
im just worried its an injector problem b/c i heard its $$$$ but i dont really know how much they are
Your K&N intake probably isn't doing you any favors. Other than that I can't help you much.
i know it came with the truck when i got it in november
im just trying to get some things done to it before i go back to school and i will be driving 100 miles in a couple weeks for a few weeks
it could be a leaking diode or wiring problem
with the alternator plugged in the orange wire should be hot at all times but the other should not
i check the voltage and i have 9.5 on the orange wire
but when i check one of the batteries i had 12.3 on the post and 10.5 on the connection to the post so that should be a dirty connection problem
the other problems is what worries me and it seems to take a second longer to start up than usual
Clean all battery connections and coat the terminals with noalox before putting the clamps on. This will help with conductivity and also help to stop corrosion. Do you know how old the batteries are? Low batteries can cause all sorts of problems with these trucks. You may want to consider changing out both batteries.
As for that P-603 internal kam error, thats normal with our Superchips programmer. I got it too and is no worries, just the truck letting you know its chipped.
im clean them and see what happens
they were both replaced in november
