i cleaned the battery post and the light still stays on with the ignition off but goes off when the ignition is turned on
but after a week the truck still turns over great like there is no lost of battery life
Did you check and clean the black/orange wire that connects to the alternator. That stud should show battery voltage. If not, the wire itself may be damaged or corroded somewhere in between.
