I have a holley 7rt-9510a (AA-1) and need pics of the the throttle/choke linkages so I can connect it up and I need the initial idle speed screw settings.
For initial set, I put the screws all the way in and then backed them off 1 1/2 turns. It was close and idled fairly well needing only minor additional adjustment.
Reason: wrong oicture
The factory manual says gently tighten the idle screws until they seat then back them up just one full turn for intial adjustment , which was close fro mine.
