Initial timing tdc compression or exhuast stroke?
Old Jan 29, 2009 | 11:43 AM
oscarguzzi's Avatar
oscarguzzi
Question Initial timing tdc compression or exhuast stroke?
I put a new distributor in my 1981 351W and am trying to set the initial timing. Is there an easy way to know if when I set the timing mark to 10 degrees btdc if it is on the compression or exhaust stroke?
Old Jan 29, 2009 | 01:24 PM
Conanski's Avatar
Conanski
Distributor is indexed to TDC of piston 1 on the compresion stroke. Both valves will be closed, so if you hold your finger over the spark plug hole you will feel air being pushed out as the piston raises. Use a small piece of wire in the hole to feel when the piston reaches TDC, the timing mark on the crank should then be at 0. Insert the distributor so the rotor faces post #1 on the cap when it's fully inserted, and set final base timing with the motor idling and ignition advance disabled.
Old Jan 29, 2009 | 04:01 PM
oscarguzzi's Avatar
oscarguzzi
Thank you :-)
77_F150_4x4
Nov 19, 2007 10:58 PM
sdpuff
Oct 13, 2007 05:24 PM
sdpuff
Jul 8, 2007 05:06 PM
Gil Chesterton
Mar 16, 2006 02:14 PM
rsmack
Aug 14, 2004 02:31 AM
