i have a 99 f350 with ac vent problems. air only comes out thru the defrost vents, nomatter what selection you put it in. i blows cold air but it wont move from the defrost mode. any help would be appriciated especially in this south texas 103 temp. thanks
You have a vacuum leak, as "defrost" is the federally-mandated default mode for vehicle cabin environmental control systems. When there's a vacuum leak, everything stays in defrost mode.
Though you didn't tell us everything about your truck, I'll assume you have a 4WD, 7.3-liter diesel-powered truck. That's what most on this forum have.
The most-likely place to look is at the vacuum lines that are in the front wheel-wells that control the auto-locking ESOF hub locks. Try replacing those lines with appropriate-sized (3/32") fuel line.
Pop, I am not sure it is his hubs, because he says it does it all the time. It would only come out the defrost when he turns the switch to 4x4. Might be the pump is not working.
I would turn the key on while standing out of the truck to make sure the vacuum pump is working. It should come on for a little while making vacuum.
My guess would be the pump isn't working. This happened to a friends 99 4x4 SD and his pump went out. Do as Miller_feed suggested and check your vac. pump. I can hear mine come on in the morning when I turn the switch on.
Good luck and let us know what you find out.
Hal
I would also say it's not the lines at or to the hubs.....Vacuum pump or the lines leading from it that lead into the dash thru the firewall....Have not looked in a while but I think there is a vacuum line T in the mess somewhere as well.
i think it is the pump i have heard come on before but now it does't i think that is the problem, does anyone know where the fuse for it is i will check it tommorrow, also it is blowing cold air and then i blows warm air then i after a while it blows cold again i have a new compressor i need to put in but i was also looking for a picture article on how to put a bypass valve to the heater core so it can cool better thanks guy i really apprrieeeaatteee da heeeelllpppp.
