ac problems
Old Jun 18, 2008 | 07:48 AM
fireeater91's Avatar
fireeater91
ac problems
i have a 99 f350 with ac vent problems. air only comes out thru the defrost vents, nomatter what selection you put it in. i blows cold air but it wont move from the defrost mode. any help would be appriciated especially in this south texas 103 temp. thanks
Old Jun 18, 2008 | 08:06 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Do you have ESOF hubs for the 4x4? Does it blow through the defrost with your truck in 2wd?
Old Jun 18, 2008 | 09:23 AM
SpringerPop's Avatar
SpringerPop
You have a vacuum leak, as "defrost" is the federally-mandated default mode for vehicle cabin environmental control systems. When there's a vacuum leak, everything stays in defrost mode.
Though you didn't tell us everything about your truck, I'll assume you have a 4WD, 7.3-liter diesel-powered truck. That's what most on this forum have.
The most-likely place to look is at the vacuum lines that are in the front wheel-wells that control the auto-locking ESOF hub locks. Try replacing those lines with appropriate-sized (3/32") fuel line.
It's a cheap start. We'll go from there.
Pop
Old Jun 18, 2008 | 11:42 AM
SpringerPop
Correction on hose size:
I replaced each of my wheel-well vacuum hoses with 22-1/2 inches of 3/16" (4.8mm) SAE 30R7 fuel hose each side. Secured the ends with a tie-wrap.
It should last a lot longer than OEM, and it fits perfectly.
Pop
Old Jun 18, 2008 | 11:47 AM
DieselCamper01's Avatar
DieselCamper01
Good info Marv. Reps to ya!
Old Jun 18, 2008 | 12:29 PM
miller_feed
Pop, I am not sure it is his hubs, because he says it does it all the time. It would only come out the defrost when he turns the switch to 4x4. Might be the pump is not working.
I would turn the key on while standing out of the truck to make sure the vacuum pump is working. It should come on for a little while making vacuum.
Old Jun 18, 2008 | 12:54 PM
Red Monkey's Avatar
Red Monkey
My guess would be the pump isn't working. This happened to a friends 99 4x4 SD and his pump went out. Do as Miller_feed suggested and check your vac. pump. I can hear mine come on in the morning when I turn the switch on.
Good luck and let us know what you find out.
Hal
Old Jun 18, 2008 | 02:13 PM
SpringerPop
Sound advice, indeed.
But I'd STILL change those hoses!
Pop
Old Jun 18, 2008 | 02:38 PM
miller_feed
Pop
You are correct about the hoses. I changed my vacuum lines a few years ago. Factory lines are crap and rot quick.
Old Jun 18, 2008 | 03:01 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
I would also say it's not the lines at or to the hubs.....Vacuum pump or the lines leading from it that lead into the dash thru the firewall....Have not looked in a while but I think there is a vacuum line T in the mess somewhere as well.
Old Jun 18, 2008 | 07:13 PM
fireeater91
ac problem
i think it is the pump i have heard come on before but now it does't i think that is the problem, does anyone know where the fuse for it is i will check it tommorrow, also it is blowing cold air and then i blows warm air then i after a while it blows cold again i have a new compressor i need to put in but i was also looking for a picture article on how to put a bypass valve to the heater core so it can cool better thanks guy i really apprrieeeaatteee da heeeelllpppp.
Old Jun 18, 2008 | 07:30 PM
SpringerPop
That cold, then warm, then cold again sounds like a compressor air gap problem.
Pop
Old Jun 18, 2008 | 09:43 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
https://www.ford-trucks.com/forums/5...ditioning.html
Try this for the cold air. The vacuum issue could be a bad pump, easy to diagnose, or a leak that could be the hub lines or hidden elsewhere.
davh
Sep 27, 2010 05:27 PM
claycomotrucks1991
May 27, 2009 07:04 PM
sagicorn62
2004 - 2008 F150
Nov 9, 2007 05:22 PM
pastorattheridge
15
Sep 21, 2007 08:05 AM
RedRage
Apr 14, 2005 06:19 PM
