Sponsored by: Real Truck
tranny cooler return line
Old Jun 17, 2008 | 06:13 AM
rich250's Avatar
rich250
Can someone tell me on which side of the factory trans cooler is the return line,I want to add a second cooler so I need to tap into the return line,This is on my 2001 in my sig.
Old Jun 17, 2008 | 09:01 PM
high ho silver's Avatar
high ho silver
bump to top.
Hang in there someone will come along and check for you.
Old Jun 17, 2008 | 09:13 PM
V10RP's Avatar
V10RP
Might sound like a dumb idea, but you could always start the truck when its cold and feel which line starts to get warm first, probably not the answer your looking for but might be worth a shot
Old Jun 17, 2008 | 09:22 PM
rich250's Avatar
rich250
never mind folks I checked myself and it's the drivers side
Old Jun 18, 2008 | 12:22 AM
TP83's Avatar
TP83
dang sorry i didn't see this earlier but by following the 2 metal lines from the back of the tranny you can tap into the one with the removable fitting. i did that with my tru cool.
Old Jun 18, 2008 | 02:15 AM
cartmanea's Avatar
cartmanea
It shouldn't really matter whether another cooler is before or after the original, total head dissipation will be the same.
Old Jun 18, 2008 | 02:51 AM
aldridgec's Avatar
aldridgec
Not exactly. If it is before the radiator it will remove excess heat that the radiator one might not, but the radiator will warm it back up if need be. If it is after the radiator it will cool it off however much it can. If it is before or after the stock external cooler it shouldn't matter though.
Old Jun 18, 2008 | 03:21 AM
cartmanea's Avatar
cartmanea
I was referring to the stock external, wasn't thinking about the in-radiator one... Doe!
Old Jun 18, 2008 | 05:55 AM
rich250's Avatar
rich250
Both metal lines come front from the tranny and right by the rad. they have strip on connections the pressure side goes into the rad. and back out then into the air cooler and back out to the metal tranny line so I can just pull that hose off and run that out front to my new cooler(it should reach)then just run my return line back to the metal tranny line.I'm mounting the second cooler in front of the a/c condensor but up behind the grille instead of down behind the bumper between the rad and a/c condensor where the factory one is.
Old Jun 18, 2008 | 12:20 PM
DieselCamper01's Avatar
DieselCamper01
Hey Rich250, that is exactly what I am planning to do today!
Old Jun 18, 2008 | 10:42 PM
aldridgec's Avatar
aldridgec
Yeah, unfortunately some guys (like me), don't have a stock external! ??
Old Jun 19, 2008 | 05:23 AM
rich250's Avatar
rich250
how did you make out dieselcamper,get yours done,how did you hook it up
got mine done last night
Old Jun 19, 2008 | 07:01 AM
kenneBF250V10's Avatar
kenneBF250V10
You mean like this?
I installed this Flex-a-lite on my '01. It's hooked up after the internal radiator cooler. FYI, the return line is the line to the rear of the tranny. Both lines are on the passenger side.
Mingy
May 23, 2015 05:32 PM
Bigpipes 35
1997 - 2003 F150
Jun 6, 2013 05:28 PM
grec-o-face
Jul 14, 2012 01:42 PM
camperspecial65
Aug 2, 2004 08:33 PM
orange78oval
1978 - 1996 Big Bronco
Feb 9, 2004 02:20 PM
