Help ! Blown Intercooler !
Old Jun 26, 2008 | 02:37 AM
cartmanea's Avatar
cartmanea
He means its a lot for stock engine build strength, so head bolts, etc.
Old Jun 26, 2008 | 09:29 AM
Fluid Power's Avatar
Fluid Power
Even with stock tuning and no towing load I can get it up to 30psi without much effort????
Old Jun 26, 2008 | 01:09 PM
OZX1's Avatar
OZX1
Originally Posted by Fluid Power
I de-tuned it and put my stock air filter back in before it went to the dealer.
also..
When you say 35psi is high for a "Stock" 6.0 are you refering to the stock head bolts or turbo or what exactly?
Because I didn't think that a tuned engine with a high flow exhaust was "stock"
35PSI is just "high"... Nevertheless, I think he's referring to head bolts primarily. If you maintain that kind of high boost for extended periods (pulling a long hill with your leg in it) somethings got to give. Look forward to blown head gaskets if you persist in running it to extremes. I know that my truck has the potential to go MUCH faster for MUCH longer than I am willing to push it. Head bolts are on my wish-list... The list starts getting worked at 101,000 miles
Old Jun 26, 2008 | 06:03 PM
Fluid Power
I'm new to the whole "Head Bolt" thing. What is the advantage? Is it just that the old ones get worn out??? Are they expensive to do?
Old Jun 26, 2008 | 06:55 PM
3000 FPS's Avatar
3000 FPS
Most 6.0L diesels only produce around 28 psi when stock. The head bolts are the torque to yield type. They get torqued to a specific value and then they are turned more to stretch the head bolt. When you start pumping 35 psi boost into the engine it can stretch the head bolts even more causing the gaskets to go bad and the head itself to warp. So eventually you not only have to replace the head gaskets but the heads also. Now I will not say that every engine will fail in this way but you sure increase the chances of it happening.
triskadek
Escape & Escape Hybrid
Aug 21, 2016 09:08 AM
phish555
Mar 17, 2010 06:59 AM
Epd444
Jul 28, 2009 08:34 PM
MikeFromShiloh
25
Jan 13, 2008 07:58 PM
River Runner
Aug 11, 2004 03:44 PM
