96 abs sensor
Old Jun 15, 2008 | 05:46 PM
bridgeman's Avatar
bridgeman
96 abs sensor
Is there or where is the abs sensor on a 96 F350?
Old Jun 15, 2008 | 06:15 PM
Cuda_jim's Avatar
Cuda_jim
It's located on the top of the rear axle housing.
It's may be called a RABS, Rear Antilock Brake Sensor or a VSS too, Vehicle Speed Sensor.
Old Jun 15, 2008 | 06:22 PM
NWBronco's Avatar
NWBronco
On the '96 it is a VSS. It sends the wheel speed signal to the PSOM and ABS module. Through the PSOM it runs the speedometer. It is mounted in the 2:00 position as you look at the pinion. Some are protected be a sheet metal plate.
Old Jun 15, 2008 | 06:39 PM
bridgeman's Avatar
bridgeman
Next question is how much for a replacement and is it a pain to replace, my truck for the last couple years seemed to wheel hop (rear tires) when I applied the brakes at high speeds but this morning the abs light came on and the wheel hopping ceased for a while but now the light went out and the hopping is back so I figured that it has not been functioning properly. I guess this is a dealer only item.
Old Jun 15, 2008 | 06:49 PM
NWBronco's Avatar
NWBronco
Did you notice any flucuation on the speedometer reading associated with the wheel hop? The VSS is not a dealer item. I got one at Action Auto. I know a few folks who ordered from Rock Auto...one of the forum advertisers.
Bob
Old Jun 15, 2008 | 07:08 PM
bridgeman's Avatar
bridgeman
speedo bounces a little when braking
Old Jun 15, 2008 | 07:28 PM
NWBronco's Avatar
NWBronco
Then you've got the right repair order. The VSS provides the axle speed to both Speedo and ABS module. Since both are acting up, it is the common component.
Old Jun 16, 2008 | 06:22 AM
Cuda_jim's Avatar
Cuda_jim
If you ask for a VSS you will get the wrong part.
Rock Auto calls is ABS Differential Speed Sensor:
RAYBESTOS Part # ABS530144 around $15
Auto Zone calls it a Brake Sensor ABS:
Duralast # SU2175
Click on the link in my signature for more PSD part numbers.
agryphon
1983 - 2012 Ranger & B-Series
Apr 7, 2019 04:54 PM
baker1983
Jul 17, 2012 08:22 AM
bronco5.8
1978 - 1996 Big Bronco
Jun 28, 2005 09:57 AM
bronco5.8
Aug 13, 2004 10:27 AM
