What size bolt for ABS sensor?
Old Oct 14, 2006 | 04:46 PM
agryphon's Avatar
agryphon
What is that bolt that holds the front ABS sensor in place on my 96 4WD? Thought I needed a 1/4" 12 point socket, but thats not it...
What the heck is it???
Old Oct 14, 2006 | 10:05 PM
agryphon's Avatar
agryphon
There are two bolts, the first one is supposed to hold the sensor cable on. That came out no problem, although it didn't seem to free anything up. Is that wire supposed to detach from the sensor, or is a permanent part of the sensor?
The second bolt which holds the sensor has me stumped. I don't seem to have any socket to fit it...
I have scoured the service CD, my Chilton manual, the formus, internet... Beats me... I can't get the dang ABS speed sensor out... Not sure what the prob is. It's rubbing on the sensor ring. I can't finish putting it back together until I resolve this problem.
Old Oct 27, 2006 | 08:16 PM
tomroberts's Avatar
tomroberts
Did you try a hex key, or allen wrench.
Old Oct 27, 2006 | 09:17 PM
agryphon's Avatar
agryphon
No, the problem as it turns out, is that those things rust into place like nobody's business. You have to completely destroy them to get them out... in pieces...
Old Oct 29, 2006 | 02:53 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
The hold down bolt will take either a 3/8" socket, or a 10mm... i've seen both used (I guess it depends on the rear end housing whether it's metric or standard).
The sensor itself tends to rust in place... although I've been lucky and never had to tap one out from the inside. Just use some penetrant.. and rock it back and forth.. it'll usually come out.
Good luck
Old Oct 29, 2006 | 11:57 PM
agryphon's Avatar
agryphon
Maybe mine was just particularly bad... it took a concerted effort. The casing came out in several pieces. It was literally fused in place...
Old Apr 6, 2019 | 09:17 AM
Homer Simpson's Avatar
Homer Simpson
2000 Excursion rear ABS Bolt size 3/8 inch
Good luck
I just wanted to add that my 2000 Excursion 2WD had a 3/8 inch bolt on the top of the rear differential holding the ABS sensor in place... in case anyone comes across this thread using a Googlie search like I did.
-Homie
Old Apr 7, 2019 | 04:54 PM
AK gman's Avatar
AK gman
on my 1996 4x4 i used a 1/4 12 point on one side and had to pound a metric onto other side as it was rounded off a bit. the blocks on the other side they were screwed into were stuck on a bit
c3racer2000
1978 - 1996 Big Bronco
Mar 7, 2022 04:32 AM
BlackNGoldRules
Jan 30, 2017 09:24 AM
Taylortd
Oct 13, 2015 09:35 PM
beamundson
1997 - 2003 F150
Mar 28, 2012 04:23 PM
tivoklr
Jan 28, 2010 11:09 PM
