Gem module.... generic electronic module. Controls things like seat belt buzzer, headlights on chime, interior light delay etc. Just plug'n'play, does not need to be flashed.
No start problem could be safety neutral switch, ignition switch, starter, starter solenoid. You need to do some testing.
I wouldn't say that - I've heard of them needing to be programmed, for things like the keyless entry, and a few other things like options that are different from truck to truck.
Auto lock, etc.
But if it worked for awhile, and now a no start, that is probably something else.
If it's an auto, try it in neutral, play around with the gear selector.
If it's a manual, make sure it's in neutral and the clutch is down. It can be a lot of things...
Either way, put the key in, turn it to ON, disconnect the small wire from the starter solenoid/relay on the fender well, and then using a piece of wire (or a screwdriver) cross that small terminal to the big one going to the battery. If it cranks over, you have an interlock problem of some sort.
