Hydro Boost pressure Hose
Old Mar 8, 2016 | 01:59 PM
robert kelsey's Avatar
robert kelsey
Can someone tell me which side the pressure hose from the steering pump goes to on the hydro boost.
I doubt I got them backwards but just in case.. changing hoses should be such a simple job.
It's either that or I got a bunch of air in the system somewhere ...
Thanks in advance
Old Mar 8, 2016 | 02:19 PM
robert kelsey
And if I did get them reversed what kinda damage did I do ..
Old Mar 8, 2016 | 05:15 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
If it stops pouring rain, I'll take some pictures. Otherwise I'm useless at this point. While I've replaced the hoses in question, I did them one at a time to avoid the exact issue I believe you seem to be facing...
Old Mar 8, 2016 | 05:39 PM
Krazee Matt
Veteran: Navy
It's gonna be pouring for a while it looks like... Razzi had a 7.3 partially torn down in his driveway though. @Toreador_Diesel, could you hook a brother up with some pics of the hydroboost lines?
Old Mar 8, 2016 | 08:44 PM
robert kelsey
PROBLEM SOLVED, THE HYDRO BOOST HOSES ARE "NOT" REVERSIBLE.
I couldn't find the ptfe seals to replace the ones on the new hoses BUT I did find some 1/2 x 3/32 O rings in my plumbing box, they just barely fit inside the female half of the fitting, no leaks on test. I also put a micro drop of anti seize on the threads just incase I tear it apart again.
AND
the pulsing brake and steering is all gone.
I hang my head in shame for not paying better attention....
Old Mar 8, 2016 | 09:22 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Too late, since I just now got to this, but I do remember what happens when they fail. Don't we Matt....
Old Mar 8, 2016 | 11:16 PM
Krazee Matt
Veteran: Navy
Indeed we do... The fitting lets go while you're checking for the source of the leak and sprays ATF ALL OVER YOUR FACE BAHAHAHAHAHAHAAAAAA.
I can laugh now, it was hysterical. And I DID give you a moment of private rage time.
5X5
Jun 19, 2019 08:03 PM
robert kelsey
Mar 10, 2016 10:28 AM
Diesel 724
24
Nov 2, 2014 06:53 PM
Benny2002
Jan 6, 2008 09:55 PM
madhatch
Sep 9, 2004 05:52 AM
