Sponsored by: Auxito
Cat replacement....on the cheap?
Old Jun 11, 2008 | 09:05 PM
Clydedog's Avatar
Clydedog
....My F-150 (a 1997 California model) just came back from the shop, diagnosed with clogged catalytic converters. The truck has 4 of them and it's the upstream cats that have crumbled and clogged. The trucks got about 125,000 miles. The shocker was the repair estimate of $1,200.00 to replace the cats (useing factory replacements) and a couple hundred less if aftermarket ones are used. Being a notorious tightwad, the estimate kinda shocked me. I know that a California shop can't install a used set and that local wrecking yards won't sell used exhaust parts. So, I thought, what about craigslist.com? Could I score the section of the exhaust system I need from a private party parting out a wrecked truck, slap it in myself and then go get the truck smogged? How would anyone know?...
....So I took a look at the local craigslist.com and found a 1997 Ford Expedition that's being parted out. The Expedition is a 5.4 liter, while my truck is a 4.6. Will the exhaust fit? Should I get the section with just the cats, or snag the entire system? What do you think?.....
Old Jun 11, 2008 | 11:45 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
No, it will not fit. The "collector", where the Y-pipe meets the manifolds are 1" wider on a 5.4L than on a 4.6L.
Maybe this might get you past SMOG?:
2.25" Goerlich Catalytic Converter OBDII 608215 - 608215
$69.95
- Manufactured from high quality materials. (409 stainless steel)
- Design meets EPA and CARB emission requirements as cataloged.
- Please contact us for CARB fitment.
- 5-year/50,000 mile warranty on converter body.
- 25,000-mile warranty on emissions.
Goerlich makes good, high-quality exhaust components. Their mufflers are much better than Blowmasters
Old Jun 11, 2008 | 11:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Sorry 'bout that...I posted the wrong one (You need the 2.5" diameter version)
You can find it here:
Exhaust - Catalytic Converters - Goerlich - OBDII by Design
Old Jun 12, 2008 | 10:48 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
I assume your talking 1 inch wider between the two down tube. that is correct. I swapped my 5.4l it to my 4.6l and used the stock downtubes. i just had to split the y pipe and spread it out about an inch or so.
RJR99SS
Apr 7, 2010 09:31 PM
basfire
Feb 1, 2008 06:20 PM
SRT77
Mar 23, 2007 04:27 PM
JoeSwing78
116
Oct 20, 2005 10:04 PM
RGAZ
Jun 8, 2000 06:07 AM
