Seatbelt Warning
Old Jun 10, 2008 | 08:13 PM
tractorguy1's Avatar
tractorguy1
Seatbelt Warning
I just bought a 2004 F-150, ext cab XLT. It has an intermitant problem with the seatbelt warning buzzer. Even with the seatbelt done up the chime will go off at regular intervals. Relatching the seatbelt sometimes works or hitting a bump in the road the right way will also correct the problem. I looked for a loose connection but couldn't find anything obvious. It also has a power seat. Any help would be appreciated.
Thanks
Old Jun 11, 2008 | 06:01 PM
kenwowski's Avatar
kenwowski
try turning it off via the directions in your owners manual that will shut the noise off for good
you can do it for both the driver and the passenger
Old Jun 11, 2008 | 07:03 PM
Twinsdad98's Avatar
Twinsdad98
Sounds like there is an issue with the belt minder system. I would check the harnesses under the seat to make sure they aren't pinched or damage by the seat tracks.
Old Jun 11, 2008 | 08:18 PM
tractorguy1
Thanks for tips guys, shutting the chime off sounds like the cheapest way
Thanks
tck2165
15
Feb 4, 2011 11:35 AM
whalerron
Jun 8, 2010 06:49 AM
truckmonger1
Oct 31, 2009 01:36 AM
vcrisis311
2004 - 2008 F150
Jun 2, 2004 07:29 AM
