1966 - 1977 Early Broncos
ignition switch wire heating up
Old Jun 10, 2008 | 06:10 PM
tomsash's Avatar
tomsash
A wire going from the ignition switch to the firewall gets almost to hot to touch. well this truck is running,Truck starts and runs fine
This is a 73 bronco
Any help would be great
Thanks
Old Jun 10, 2008 | 08:00 PM
MMB's Avatar
MMB
Resistance Wire
Sounds like it is the resistance wire that runs from the run terminal of the ignition switch to the BAT terminal of the coil to limit current through the primary windings. It can get warm to the touch but is not one of Ford's better ideas.
Old Jun 10, 2008 | 09:18 PM
dodmort's Avatar
dodmort
been there
toasted that.
if u go anywhere long way from parts store better take
1, new ingnition switch
2, some wire
3, ballast resistor
that way at least you can make it back to town.
Old Jun 11, 2008 | 01:45 AM
Fordteamone's Avatar
Fordteamone
Smile Warm wire
I second dodmort, I have had a 68, 69, 72 and 74 Bronco all had the wire running warm to the touch under the dash. The tool box has always had spare ignition parts, wire, ballast resister and sometimes coil even the electronic kits I have had can let you down. There’s been more than one time we have had to hot wire a rig to get back to town. If fact one time at work using a 5 ton truck to relocate equipment, it died on the freeway (Dodge and a burnt ballast resistor) the guy I was working with just freaked out. Well I always try to take my small tool jump bag anytime I use a rig other than mine, out come three feet of wire, ballast resistor and we were on the road to NAPA. Tools, parts and FTE really help in life.
Old Jun 11, 2008 | 03:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Resistor wire
1973 and later Ford cars & trucks.
D7AZ-12250-A .. Resistor Wire (Motorcraft DY-213)
49" long / color coded red with/without green stripes / 1.30 to 1.40 ohms resistance / #16 gauge wire.
1960/72's use C0LF-12250-A (Motorcraft DY-37)
Color coded pink / 61.50" long / other specs the same as above.
Old Jun 11, 2008 | 08:02 PM
tomsash's Avatar
tomsash
Thanks for the replys changed the wire now just a little warm
Old Jun 11, 2008 | 09:59 PM
dodmort's Avatar
dodmort
the only time i have ever had any vehicle leave me was a 84 bronco with 200 grand on an all orginal set up...had all the right extras with me...except a coil...guess what it was....and the replacement went out 6 months later...the extra parts are not expensive..so my obd 1 and less stuff has it.. the obd2 and newer gets towing insurance and my wife drives that stuff....anywho......
raven3
Apr 10, 2014 10:15 AM
jfarcas
Nov 29, 2007 09:19 AM
gp42gpw
Nov 1, 2007 02:06 PM
mitchw32
Jan 31, 2005 08:21 PM
