Sponsored by: Auxito
Trans fluid change gone wrong
Old Jun 10, 2008 | 12:21 AM
o_i_f_03_04's Avatar
o_i_f_03_04
Cool Trans fluid change gone wrong
I recently went to Jiffy Lube had the transmission flushed and changed the oil in the transfer case. Now my truck is making a knocking noise when i slow down to stop, accelerate, and drive in reverse. It does not do it all the time but about half the time. Any help would be greatly appreciated i'm towing a 6x12 trailer 2000 miles in 10 days from now and would like to figure this out before my trip.
Old Jun 10, 2008 | 05:38 AM
96f150's Avatar
96f150
You mentioned "oil" in the transfer case. Is that what they put in there? gear oil? If so, you had better have them drain it out. The T-case takes roughly 2 quarts of ATF just like the transmission.
Rich
Old Jun 10, 2008 | 07:32 AM
o_i_f_03_04
I dont know what they put in the T-Case, but i do know that they put some of there tranny fluid in the tranny and i paid extra for a additive they said would make it mercon-v
Old Jun 10, 2008 | 10:47 AM
KingRanchMan02's Avatar
KingRanchMan02
Mercron V is a fully synthetic transmission fluid. No additive can be added to standard transmission fluid to make it meet Mercron V specifications. Either do it yourself or take it to the dealer for a fluid change using Mercon V. Good luck!
Old Jun 10, 2008 | 11:08 AM
montanafordman's Avatar
montanafordman
I think you're problem can be identified by "Jiffy Lube" alone.. I've never had any luck at those quick lube places. I think twice was all it took for jiffy lube to put the wrong weight oil in my truck when I EXPLICITLY told them to put the correct oil in - its even printed on the dang filler cap! Another place I tried to get the trans fluid flushed and they couldn't get the lines off without worrying they were going to break or strip something on the radiator. From those experiences I will NEVER take my rig to a quick lube place (esp. jiffy lube). Instead I do it myself or pay the premium and take it to the dealer.
blrman1962
Sep 1, 2011 09:37 PM
Chickenguts
1983 - 2012 Ranger & B-Series
Feb 26, 2010 10:11 AM
TheMech
Dec 1, 2008 10:36 AM
SUPERDUTY_08
6.4L Power Stroke Diesel
13
Jun 8, 2008 04:02 PM
focusinc
15
Oct 17, 2005 10:23 PM
