400 Cam
Old Jun 18, 2008 | 06:25 PM
hollenjoe's Avatar
hollenjoe
One last thing, to compare, if you have time can you estimate my engine for me?
specs:
400 + 0.030" over = 408
stock 2v cleveland heads 2.04 In 1.66 Ex
scr: 10:1
750cfm carb
singleplane small (or standard) port manifold
large tube headers open exhaust
camshaft: XE274H (extreme energy 274 comp cam)
lift at valve: It: 0.562" Ex:0.565"
valve timming: seat to seat : IVO: 27 IVC: 67 EVO: 73 EVC : 33
0.050": IVO: 5 IVC: 45 EVO: 48 EVC : 8
Thnx Danlee
Old Jun 18, 2008 | 07:02 PM
danlee's Avatar
danlee
The torque @ 2000 RPM is 393 ft-lbs and peak torque is 449 ft-lbs@4000 RPM. The peak HP is 395@5000 RPM.
A good dual plane manifold would help at low RPM.
Old Jun 19, 2008 | 11:27 AM
hollenjoe's Avatar
hollenjoe
Yeah im plannning on using the weiand, I guess both dynosyms are a bit different, also those results you are giving me i get them exactly in my dyno with 1 point less is cmopression ratio (9:1) , anyways this are the result i get with dyno 2003 ( I guess this Sym is a bit on the bright side now that i see yours):
torque:
414@2000
465@4000
hp:
416@5000
And of corse the difference could also be in the fact that you can use both timmings in the camshaft part, anyways thanx alot man...
Old Jun 25, 2008 | 09:15 PM
Mud Rat's Avatar
Mud Rat
I used a 262 grind Crane
Old Jun 30, 2008 | 06:56 PM
ncl's Avatar
ncl
I have the K5200 I put it in about 5 years ago truck runs good but I want headers to waken it up. I had gotten the edlebrock cam that is comparabel but returned it when I found the summit cam. It is the same cam but a little better price.
Oh hey Dan lee You ran numbers for me before could you run them again using the K 5200. My engine is 400 bored .030 over edlebrock 1406, edlebrok performer dual plane intake, stock heads, pistons unknown probably 9:1. I run manifolds now but hope to get some Sandersons for it running a single 3" exhaust.
Old Jun 30, 2008 | 07:00 PM
hollenjoe's Avatar
hollenjoe
were can i get your specs, or post them i can also help you...
Old Jun 30, 2008 | 07:10 PM
danlee's Avatar
danlee
With that setup, I get 378 ft-lbs torque@2000 RPM, and 390 ft-lbs@3500 RPM. The peak HP is 278@4000 RPM. It definitly needs headers to get the high RPM power.
What makes you think that it's 9:1 CR? Most replacement pistons are dished and produce lower CR.
Old Jun 30, 2008 | 08:49 PM
ncl's Avatar
ncl
Well the previous owner who told me about the motor said they had a motor shop build the motor and they did some mild performance mods to it. The cam I pulled out when I put in the summit was a high energy 268H cam it was stamped on it. He told me he blew the original 400 in the truck then they took a 351m and put a 400 crank and pistons and bored it out. So I am just assuming, I know the shop that built it was primarily a high performance shop. They did a good job since it still is goig strong 20 plus years later after some serious abuse from my friend who was the 2nd owner I am the third. The numbers you have I assume are with headers?
Old Jun 30, 2008 | 08:57 PM
danlee's Avatar
danlee
No that's with stock exhaust manifolds. With headers it goes to:
433 ft-lbs torque @2000 RPM and 436 ft-lbs @3500 RPM. The peak HP is 315@4500 RPM.
Old Jun 30, 2008 | 09:02 PM
ncl's Avatar
ncl
Wow that summit cam runs pretty good are the numbers a lot lower with stock pistons.
Old Jul 1, 2008 | 05:05 PM
OldBlue68's Avatar
OldBlue68
well since your running everyone elses hp numbers could you run mine please ?
400 with mild head work, not sure what i believe mild porting and milling, bored 30 over eldebrock cam , intake, 670 cfm holley , hedman full length headers, im not sure of the pistons though..
breezesboy
Sep 18, 2015 12:39 PM
madrockwyo
Mar 3, 2015 01:04 PM
Bigbruce
Sep 25, 2013 07:34 AM
cruz76
May 21, 2007 12:08 PM
bruce351
Aug 28, 2003 10:09 AM
