York 210
Old Jun 9, 2008 | 02:20 PM
notlowyet's Avatar
notlowyet
York 210
I was wondering if there was a bracket to bolt a York 210 compressor onto my 302? I don't have power steering or A/C, so there is plenty of room. I'm looking for one so that I don't have to work so hard to line up the pulley with the rest of the pulleys.
Old Jun 11, 2008 | 09:17 PM
tankrsc's Avatar
tankrsc
York 210. Is that the sqare one? Do you want the stand-up or the one that is laid on its side?
Old Jun 11, 2008 | 10:04 PM
notlowyet's Avatar
notlowyet
yeah, its the older style square one, I was looking for hopefully the stand up bracket. Which side of the motor does it fit on, because I have plenty of room on the driver side.
Old Jun 11, 2008 | 10:36 PM
donnor's Avatar
donnor
"compressing" your thoughts...
I believe virtually all of those older York & Tecumseh compressors mounted on the driver side so you should be able to find one somewhere. I assume you will also be using traditional v-belts not a serpentine style and are trying to maintain a timely underhood "look". Otherwise the newer style compressors usually take less power to drive. What about refrigerant? R-12 or R134? Will you also be adding power steering? A complete swap-in may make the whole job easier. Even so, some customizing may be needed to obtain the right alignment of pulleys.
Take a complete inventory of all possible variables and associated costs before jumping in. (Just a little voice of previous experience...)
dn.
Old Jun 13, 2008 | 04:40 PM
78ltd's Avatar
78ltd
I thought all the 302's had the "on the side mounting" on a common
bracket with the power steering pump. And a idler arm for belt tension.
Am I wrong?
Old Jun 13, 2008 | 08:38 PM
tankrsc's Avatar
tankrsc
I thought I had one. Thats why I was asking but I have looked and seems to have grown legs and walked off, sorry.
teds74ford
Feb 5, 2013 07:36 AM
f-trucker88
Aftermarket Products
27
Jul 28, 2012 05:28 AM
F250racer
Offroad & 4x4
May 2, 2011 08:51 PM
etcetera
Offroad & 4x4
17
Nov 26, 2007 08:22 AM
