P1635 Error
Old Jun 7, 2008 | 02:05 PM
MIKESANDS's Avatar
MIKESANDS
P1635 Error
Can anybody help me? My CEL is on and I pulled this code...I made the mistake of using a Hypertech programmer and the code came on soon after. I do have a stock code I saved from my SCT, would it fix it if I put it back in? any help would be appreciated!
Old Jun 7, 2008 | 02:06 PM
MIKESANDS's Avatar
MIKESANDS
I meant stock tune file...
Old Jun 9, 2008 | 11:29 AM
MIKESANDS's Avatar
MIKESANDS
Well, I guess I stumped the panel on this one! That can't be a good sign...
Old Jun 9, 2008 | 11:46 AM
69cj's Avatar
69cj
P1635 = 5 volt reference low.
google "obd2 and code number" will give you just about any code out there.
Old Jun 9, 2008 | 12:18 PM
MIKESANDS's Avatar
MIKESANDS
I got "tire and axle out of range"...
Old Jun 9, 2008 | 01:12 PM
PowerStrokeHD's Avatar
PowerStrokeHD
P1635 - Tire/Axle Out of Acceptable Range
DTC indicates the tire and axle information contained in the vehicle ID (VID) block does not match the vehicle hardware. Could be caused by incorrect tire size, incorrect axle ratio, incorrect VID configuration parameters.
Sounds like a programming error in the VID block causing a conflict. Like you suspect, it could be your programmer...
Old Jun 9, 2008 | 01:15 PM
OZX1's Avatar
OZX1
Look here...
Mike-
There's an old thread on this issue that might help:
https://www.ford-trucks.com/forums/5...tc-code-s.html
Brian
Old Jun 10, 2008 | 10:43 AM
MIKESANDS's Avatar
MIKESANDS
Do you think re-programming with a good stock cal would clear it?
Old Jun 10, 2008 | 11:00 AM
PowerStrokeHD
I am thinking it would be worth a shot... If you took it to a dealer the first thing they are going to do is check the parameters of the VID block and more than likely reprogram it...
The issue is strictly programming related from everything I have read...
Old Jun 10, 2008 | 11:14 AM
69cj's Avatar
69cj
Sorry about the wrong info. I thought OBD 2 codes were generic but apparently they are brand specific. The 5 volt reference code is for GM and Isuzu. P1635 for Ford is indeed the tire reference dimension.
Old Jun 10, 2008 | 11:40 AM
MIKESANDS's Avatar
MIKESANDS
No problem, I saw that also..it gets confusing. I appreciate any info/help I get!
Old Jun 10, 2008 | 11:41 AM
MIKESANDS's Avatar
MIKESANDS
Boy, I wish I'd kept that SCT X3!
Old Jun 10, 2008 | 08:19 PM
elee3's Avatar
elee3
Mike, from reading a lot of your posts, it seems like you have had just about every programmer made and hated them all.lol. Which one did you hate the least? I'm looking to trade in my flashpaq for an SCT, is that a good move?
Old Jun 10, 2008 | 08:34 PM
OZX1's Avatar
OZX1
elee3- My SCMT1704 upgraded to the same tune level as an 1804 FlashPaq wasn't nearly as impressive and functional as my X3, IMHO...
MIKESANDS's Avatar
MIKESANDS
So my secret is out!
With the right tunes the SCT would be my choice, I have tunes from Spartan but he refuses to send me the new ones. And I have tunes from Innovative, Eric has been great!, very responsive..I'm searching for the elusive mileage gain and I just can't find it. Eric's Gen Econ tunes is a great daily tune but I didn't see any mpg increase, so I tried the Hypertech..what a mistake!
