thus when accel from stop
Old Jun 6, 2008 | 07:38 PM
whiskeyrichard's Avatar
whiskeyrichard
When I start from a complete stop, I get a thud. There is no sound associated with it, but it feels like a thud.
I can sometimes feel the same thud when I top if I stop abrubtly at a slow speed.
I have done some research here and it sounds like the issue with the drive shaft needing lubrication, or axle wrap, although I do not really understand what axle wrap really is.
I do not get any vibration and anything other than the initial thud on take off.
WR
Old Jun 6, 2008 | 07:47 PM
F350-6's Avatar
F350-6
Greasing the slip joint would be a good place to start.
Axle wrap is the axle rolling or rotating slightly from the torque applied to the rear end from the drive shaft. When the axle rolls slightly it changes the angle of the drive shaft which can cause a problem. It doesn't sound like this is your problem.
Old Jun 6, 2008 | 07:55 PM
ron's power stroke's Avatar
ron's power stroke
you feel it or hear it?? if you feel it..is it on your feet??..could be sway bar bushings..when you grease the shaft like Chis had said..check your bushings...
Old Jun 6, 2008 | 08:38 PM
whiskeyrichard
I feel it, but do not hear anything. I feel it mainly in the seat and my feet.
WR
95ranger95
1983 - 2012 Ranger & B-Series
13
Mar 12, 2009 12:38 PM
KCGman
Dec 18, 2008 07:30 AM
ksdeuce
1997 - 2003 F150
Nov 2, 2008 09:08 PM
bbuffalo
Jun 30, 2003 10:48 AM
robber
Feb 12, 2001 10:14 PM
