Sponsored by: Real Truck
Spring Wrap
Old Dec 14, 2000 | 12:19 PM
robber's Avatar
robber
Spring Wrap
Has anyone out there experienced a heavy thud coming from the rear when you accelerate from a stop. It always seems to be there although it varies in magnitude some depending on how hard I brake when coming to a stop. Sometimes, there actually seems to be two thuds. I can feel a similar thing as the truck settles during stopping. The dealer say it is spring wrap and it is normal. I remember spring wrap from my earlier years when we installed traction bars to stop wheel hop and to keep from breaking springs. This seems different. I have checked for loose bolts, spare, etc. and can find nothing. I would appreciate any insight.
2001 F250 SD/SC LWB 4WD V10 373LS
Old Dec 16, 2000 | 10:15 PM
daisy's Avatar
daisy
Spring Wrap
Had same trouble with mine along with many others. After many trips to dealer they discovered an improperly torqued yoke on transfer case.
Old Dec 17, 2000 | 11:10 AM
robber's Avatar
robber
Spring Wrap
Thanks, Daisy. Hopefully, this is the same thing and easily fixed. Some dealers seem very ready to call any problem that shows up "normal" for the truck and, therefore, acceptable. It has been interesting trying to get their attention.
Robber
Old Dec 18, 2000 | 07:15 PM
robber's Avatar
robber
Spring Wrap
Daisy,
Did your dealer explain what the transfer case yoke was? Mine seems to have a problem understanding exactly what I am talking about.
Robber
Old Dec 18, 2000 | 08:00 PM
daisy's Avatar
daisy
Spring Wrap
I am trying to find my paperwork on this repair. The fix for it came from Ford, and I know it was an improperly torqued yoke in the drivetrain. When I find the paperwork I will reply.
Old Feb 11, 2001 | 08:29 PM
paulb32's Avatar
paulb32
Spring Wrap
I just wanted to post that I had this same 'thud' problem and my local ford dealer fixed it with no problem. Although, my F350 has been in for 7 other repairs plus recalls and tomorrow I take it in for a broken leaf spring. The sad thing is, I bought this truck for its great looks, I dont even haul anything or tow anything with it and I have 1 broken leaf and 1 missing leaf from the drivers side. I am not happy at all with this purchase, I honestly wish I could say I was.
Old Feb 12, 2001 | 06:01 PM
robber's Avatar
robber
Spring Wrap
Sorry to hear about your problems. I also have a few issues but, except for this particular problem, nothing major. Do you recall what the dealer did to fix the "thud"?
Old Feb 12, 2001 | 06:50 PM
paulb32's Avatar
paulb32
Spring Wrap
I wish i could say what the dealership did but at that time I took my truck in for the 'thud' noise as well as 3 other noises. The rear end 'thud' always sounded as if I had a heavy object in the bed and when i took off it would be the 'thud' you would hear when that object hit the tailgate after it slid across the bed liner.
I mentioned that 'thud' along with a clunking in the front end as well as a 'thud' in the front end after starting the vehicle and letting it warm up for about 5 mins. They determined that front end 'thud' to be the power steering pump. They replaced it and its fine.
The Work Order reads like this even though they were trying to identify a front end problem.
D CS. Any time Turning left or right clunking type noise in FRT END. CAUSE: 38331 49 Road Test Verify Chatter Concern After Warmup, CK, OASIS and Found SSM.11768 Drain REAR DIF. ADD 2 8 OZ.FRICTION MODIFIER and REFI
4 F1TZ*19580*A MULTIPLE SUPERCESSIONS
Not sure if that helps you any.
Old Feb 12, 2001 | 10:14 PM
FTE Ken's Avatar
FTE Ken
Spring Wrap
bconstiner
1983 - 2012 Ranger & B-Series
Dec 29, 2012 09:37 AM
mike242424
Jun 30, 2009 10:44 AM
cjgeorge32
20
Oct 20, 2008 02:46 PM
whiskeyrichard
Jun 6, 2008 08:38 PM
KenShaw
Mar 26, 2008 08:41 AM
