overdrive in a 4X4
Old Jun 6, 2008 | 10:19 AM
Flyn66dtmn's Avatar
Flyn66dtmn
overdrive in a 4X4
Just a passing thought, took my new 66 3/4 4 WD and my camper and went camping over the weekend and got to thinking , boy sure would be nice if this thing had an overdrive for traveling down the hiway. perty obvious that it wouldn't work in 4 WD mode but going down the hiway would sure be nice. about 20 years ago i talked to a feller that thought he could get one that bolted to the rearend. is this possible or does anone have a place where i could start looking. may be to pricy to do anyway. Dutch
Old Jun 6, 2008 | 02:05 PM
airharley's Avatar
airharley
I have seen guys add an extra manual transmission to drop their ratios even farther. What would keep you from putting one in backwards? Ok so the grears would self distruct after a while. But it is a thought.
Old Jun 6, 2008 | 02:14 PM
Flyn66dtmn's Avatar
Flyn66dtmn
LOL can you imagine the amount of work that would be just trying to figure out how to shift it. i think I'll look for something that'll bolt up. dutch
Old Jun 6, 2008 | 02:49 PM
airharley's Avatar
airharley
That is easy, buy a cheap manual shifter that you can mount in the cab. Make a link with rod ends to attach to the actual second shifter that you cut down to size. Bolt the forward end of the link below the pivot point so it matches the input in the back. Just be sure to lock reverse out otherwise that would get intersting really fast. Or worse then that forgetting your in final drive and dropping into 4x4 mode. You would have to relabel the shifter **** as well. As a saftey feature wire a LED to indicate when you aren't in normal ratio.
3rd would be normal ratio, 2nd would be your first overdrive, then 1st would be your final drive.
I think the hardest part would be making the splined yoke to attach to the maunal trannies "input" shaft.
Just throwing ideas out there is all.
Old Jun 12, 2008 | 11:36 AM
snortf100's Avatar
snortf100
I to have wanted this conversion. Here is a respnse from High Impact Wheels:
the simplest answer would be a Ranger Overdrive. $1475.
http://high-impact.net/transmission _and_gear/rangeroverdrive.htm
We could also do an NV4500 conversion, but we would have to use a different Tcase; I don't show any adapters for your Tcase. This system would cost more as well, more like ballpark $2500, plus is different Tcase such as an NP205F or such.
Greg Miller
High Impact Wheels / Transmission & Gear
Toll Free 888-898-4331
High Impact Beadlock Wheels and Gearing Options
Note: Conversions are not an exact science. Part of our service includes going over your job in detail when you place the order, and verifying the engineering to ensure you have the best engineered kit for the job using the best data we have available to us. Unforeseen variables can come up during the install: We also provide full and available technical support after you receive your parts, any questions or difficulties you might have before, during or after the install.
Old Jun 12, 2008 | 12:59 PM
Flyn66dtmn's Avatar
Flyn66dtmn
yikes, i doubt that it is not goning to happen at that price as all i do with the truck is pull my camper around close to home. with the price of fuel i cant afford to do any lengthy trips. i'll put the anme of the company on my wish list and hint to the wife 30 or 40 times LOL that i'd really like to do that. i may sit down with a calculator and estimate what the payback time would be for the amount of time and miles i drive the truck. i know i would drive it a whole lot more if it had one. the milage may not go up enough to justify the time and expence. and that prolly wont be known until it is installed and driven for awhile. Dutch
Old Jun 23, 2008 | 08:08 PM
modeleh's Avatar
modeleh
Do a search online or ebay for Hone Overdrive, or Hone-O-Drive. They were made in the 60s and 70s in a couple different variations, one bolted to the front pinion carrier of a 9" Ford housing. Some Toyota Landcruisers were equipped with them from the dealer (or factory?) I am currently putting one in my '32 Ford BB but have yet to get it on the road to try it out. It is approximately a 30% overdrive.
jg96powerstroker
26
Nov 22, 2011 06:24 PM
bighalt56
Jan 10, 2011 10:57 AM
crazymut
15
Mar 2, 2010 02:32 PM
matttt74
Apr 13, 2004 09:52 AM
matttt74
Apr 11, 2004 05:03 AM
