gears
Old Aug 14, 2011 | 02:33 PM
jg96powerstroker's Avatar
jg96powerstroker
gears
ok guys in no its asked a loy and i think i have as well... my new job i drive hiway a lot more now and dont have to pull sa much... i have 4.10 gears with 37 at 70 iam running bout 2600 or 2700 rpm,, but most hiways are 75 but run 80 so you dont get ran over.... would i be better off with a 3.73 gear ??? not sure if i will lose a lot of power and gain much in milage, or not was thinking 355 was to hi but not sure.. could use your help guys.. also where is a good place to get gears??? would like to just replace them not intirer frount and rearend.. thanks for the help guys d60 upfront and stock f250 rearend
Old Aug 14, 2011 | 04:32 PM
arkredneck's Avatar
arkredneck
You could put a gear vendors overdrive in it but thats kinda expensive i looked at re gearing my big truck and was told it would cost $1000 an axle for parts and labor and they say the tools to do it yourself ain't cheap
Old Aug 14, 2011 | 05:10 PM
jg96powerstroker
would you do 373 or go with the 355??? yeah gear vender is hi... ill be out the cost of parts... got a buddy that dose gears.. where is a good place to get gears
Old Aug 14, 2011 | 05:24 PM
tshrager's Avatar
tshrager
I've dealt with randys ring and pinion before and they were reasonably priced and they had great customer service. I'd definitely buy from them again if I needed to
Old Aug 14, 2011 | 05:45 PM
jg96powerstroker
do the have a wed page??
Old Aug 14, 2011 | 05:55 PM
fordpride's Avatar
fordpride
Here ya go
Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.
Old Aug 14, 2011 | 07:00 PM
427 fordman's Avatar
427 fordman
If I were you I'd go with 3.73's. I someday am going to put them in mine. I like my 3.55's but would like about 200rpm more when pulling at like 70, and that is what I do most. I speed up it works better, but I don't want to buy lots of blown trailer tires either so I keep it at 70 or less when hot. You'll knock off 300+ rpm going to 3.73's from 4.10's.
arkredneck's Avatar
arkredneck
I hate my 3.55 or towing in my 96 2wd f250 but good on highway
When I redo my big truck nothing average or factory is gonna work it will have to
Be the best of the best if I wanna keep my 1 ton running gear axle shafts for the front are $1500
Just ask your self what your gonna do with the truck
Old Aug 14, 2011 | 07:46 PM
jg96powerstroker
ok cool yeah 300 - in rpms would be sweet!! i can pull any thin i want or need to now.. ithink a 373 would be a good gear.. you can still pull and get good hw milage as well thanks man
Old Aug 14, 2011 | 08:34 PM
bad12jr's Avatar
bad12jr
My buddies sd has 373 at 55 to 60 I think it needs more rpm. It kicks down alot towing 8000. Its a 4r100 though. Pulls good when it shifts. I just hate it.
Old Aug 14, 2011 | 10:52 PM
oldbird1965's Avatar
oldbird1965
Jason, I like my 4:10's but I also have stock size tires. 3:73 probably would be good with your tires.
Old Aug 14, 2011 | 11:57 PM
towsrus's Avatar
towsrus
with 37's i would keep your 4.10's. i would think 3.73s would be a little doggish on 37 inch tires. i got 3.73s on 35's and am going to be going the 4.10 route on the 35's. couldnt picture 37's with a 3.73 there is a reason it came as a stock gear with 275 tires from the factory. i do know the motors have the torque to turn the tires, but when you start depending on the torque of the engine to turn the tires instead of the correct gearing, thats when things start to break
Old Aug 15, 2011 | 01:54 AM
GreaseMonky's Avatar
GreaseMonky
I know someone has already suggested the gearvendor, and I know there high in price, but I my self think they are well worth it, i know in my suburban i have one and at 2000 rpm, i engage it i drop to 1500, they say its a 25% drop in rpms across the board so the more rpms you run the more drop you gain, and you can over drive the gears inbetween which make it great for pulling grades, before in my suburban i would pull hills where 3rd was to tall of a gear, and second was to short, but now i can do second over on the gear vendor and its great, they say you can also pick up 25% more mpg, and i think i actually get better then that in my suburban
Old Aug 15, 2011 | 10:21 AM
dclack's Avatar
dclack
I got 3.73s with 33s and run about 2200 rpm at 70. I got used SD gears. The rear set I got off eBay and the front set from a junk yard I found on Car-Part.com. If you get OEM 10.5 gears, you need to use an inner pinion bearing for a 10.5.
Old Aug 15, 2011 | 05:37 PM
joe_13894's Avatar
joe_13894
You're thinking "upside down" in the sense that the bigger tires make his truck already geared lower.
