Overheating
Old Jun 5, 2008 | 09:18 PM
abnjumpmaster's Avatar
abnjumpmaster
Overheating
My 1979 F100 w/ 351M Automatic and Air Conditioning is running very hot. Other then flushing the radiator and installing new thermostat should I do anything else?
Old Jun 5, 2008 | 09:23 PM
petes79f150's Avatar
petes79f150
How's it running, other than hot? What kind of shape is she in? All original?
Pete
Old Jun 5, 2008 | 09:29 PM
abnjumpmaster
Runs good, near perfect condition. I really wouldn't have known running hot if I didn't look at the gauge (the gauge is working fine and is accurate).
Old Jun 5, 2008 | 09:38 PM
Randomtasker's Avatar
Randomtasker
Ahhh, a 79 with AIR CONDITIONING? You shoud give up on it immediately and just sell it to me. I had to try. Seriously though, I'll interject a few ideas, and I am curious about a couple things...
First the interogation: Have you checked your oil for water, or your radiator for milky foam? This could be a head gasket / warp problem. Has your TRANSMISSION been acting strangely lately? (Don't be insulted by this, but...) Did you cover your radiator last Winter to help the truck warm up faster? - did you remove the cardboard or whatever?
Ok, that aside, if the radiator has ever leaked in the past, or if the heater coil has, mabybe somebody has just packed the cooling system with bottle after bottle of stop leak, which can build in the system and block water passage.
The radiator CAP may no longer hold pressure and need replaceing.
There may be too much Antifreeze and not enough water in there, check with a hydrometer.
Hows the belt on your water pump? How is your fan shroud????
Old Jun 5, 2008 | 09:39 PM
Randomtasker
If all the above is fine, I'd replace the thermostat!
Old Jun 5, 2008 | 09:53 PM
abnjumpmaster
Thanks everyone, I will check all the above tomorrow
Old Jun 5, 2008 | 10:19 PM
fmc400's Avatar
fmc400
MSEE
Also check that the fan belt is tight. Late ignition timing can cause overheating as well. You should also be using a fan shroud.
Old Jun 6, 2008 | 02:54 AM
77red4x4's Avatar
77red4x4
Ditto the fan belt recommendation. Probably the same belt that drives your water pump, too. I couldn't hear mine slipping over the engine and tire noise but finally heard it squeal when I revved it up in my garage. Still not sure if it was slipping on the water pump or the fan but I suspect it was the water pump.
Old Jun 6, 2008 | 04:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When new, these trucks came with 192 degree thermostats...ppl complained about the gauge climbing towards hot while driving in heavy stop and go traffic, so Ford sent a letter to dealers telling them to install 180 thermostats if a customer complained.
This was done under warranty and only (AFAIK) in desert like climates in CA, AZ, NM, NV and UT.
Ford also offered 160 & 172 degree thermostats for these engines.
Old Jun 6, 2008 | 11:36 PM
Randomtasker
Isn't is great to have a guy like numberdummy who has the answers! Thanks for the info! Your input makes this site a better place.
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
