My 1979 F100 w/ 351M Automatic and Air Conditioning is running very hot. Other then flushing the radiator and installing new thermostat should I do anything else?
Ahhh, a 79 with AIR CONDITIONING? You shoud give up on it immediately and just sell it to me. I had to try. Seriously though, I'll interject a few ideas, and I am curious about a couple things...
First the interogation: Have you checked your oil for water, or your radiator for milky foam? This could be a head gasket / warp problem. Has your TRANSMISSION been acting strangely lately? (Don't be insulted by this, but...) Did you cover your radiator last Winter to help the truck warm up faster? - did you remove the cardboard or whatever?
Ok, that aside, if the radiator has ever leaked in the past, or if the heater coil has, mabybe somebody has just packed the cooling system with bottle after bottle of stop leak, which can build in the system and block water passage.
The radiator CAP may no longer hold pressure and need replaceing.
There may be too much Antifreeze and not enough water in there, check with a hydrometer.
Hows the belt on your water pump? How is your fan shroud????
Ditto the fan belt recommendation. Probably the same belt that drives your water pump, too. I couldn't hear mine slipping over the engine and tire noise but finally heard it squeal when I revved it up in my garage. Still not sure if it was slipping on the water pump or the fan but I suspect it was the water pump.
When new, these trucks came with 192 degree thermostats...ppl complained about the gauge climbing towards hot while driving in heavy stop and go traffic, so Ford sent a letter to dealers telling them to install 180 thermostats if a customer complained.
This was done under warranty and only (AFAIK) in desert like climates in CA, AZ, NM, NV and UT.
Ford also offered 160 & 172 degree thermostats for these engines.
