door release levers
Old Jun 5, 2008 | 08:18 PM
66f-100's Avatar
66f-100
door release levers
Which way are the door latch release levers for a '66 supposed to point? I have been looking at the gallery and I see them pointing every direction. The reason I am asking is that the splines are completely gone on my driver's door and I am going to do as another member suggested and drill the shaft and put a longer screw throught the shaft. Seems like that should work. Has to be better than the mini vise-grip on there, now. Just want to make sure I have the correct orientation before I drill it. The one on the passenger side is pointing straight down in the 6 o'clock direction. I have seen a few that way, but I have seen almost every position imaginable.
Mark
Old Jun 5, 2008 | 09:16 PM
gangstakr's Avatar
gangstakr
What's comfortable to you? That's what matter's.
Seeing how your drilling the spline shaft I doubt that you entering this truck in a number judging show.
So with that said put your door handles as well as your window handles in a position that is comfortable to you.
Old Jun 5, 2008 | 10:05 PM
camperspecial65's Avatar
camperspecial65
handles are typically in the 5 o clock position...give or take a few minutes
- cs65
Old Jun 5, 2008 | 11:16 PM
66f-100's Avatar
66f-100
I'm using the set screw hole and drilling a hole perpendicular to the shaft which will allow a longer set screw to go through the shaft in exactly the same direction that the original screw went. The modification will be completely hidden.
Old Jun 5, 2008 | 11:17 PM
66f-100's Avatar
66f-100
- cs65
CS,
Is it 5 o'clock as you are looking at the driver's door or passenger door?
Mark
Old Jun 6, 2008 | 02:19 AM
camperspecial65
Passenger door...they are aimed a little bit to the rear of the cab in their relaxed position
- cs65
Old Jun 6, 2008 | 02:25 AM
camperspecial65
Old Jun 6, 2008 | 02:40 AM
camperspecial65
Old Jun 6, 2008 | 09:54 AM
airharley's Avatar
airharley
My nieghbor has his positioned at the 1 oclock and that is down right weird feeling. You have to push the handle forward to get out. I like them at the 5 or 5:30 personally.
Old Jun 6, 2008 | 09:41 PM
65-F100redux's Avatar
65-F100redux
I agree with the 5 o'clock position as cs65 describes. That's how they were in a 64 F100 I owned in 1979 and that's how they are on 65 F100 I recently obatined. My friend had a 64 with them mounted upside down (imo) like the 1 o'clock position, and it was just wrong, to me.
-Chuck
Old Jun 7, 2008 | 03:47 PM
66f-100's Avatar
66f-100
Thanks, for the replies.
Mark
Old Jun 10, 2008 | 02:51 AM
camperspecial65
I read a couple of days ago the reasoning behind the handles positioning...its safety...so you gotta pull vs push to get out...and we all know how the kids like to push on things.....
- cs65
troverman
Jun 21, 2023 07:11 AM
John Markl
Large Truck
Jan 4, 2020 04:17 AM
66f100project
Jun 9, 2016 06:58 PM
three on the tree
Mar 9, 2016 10:13 PM
mpsteil
Nov 30, 2015 07:19 AM
