PROBLEMS .... any one got an answer?
Jun 5, 2008 | 04:35 PM
my dads 1999 ford ranger with the 2.5L with an automatic...
the ANTI LOCK BRAKES light is on and the transmission will not shift out of first gear
???????????????????????? any one know whats up?
Jun 5, 2008 | 04:38 PM
is the key turned on or off, and check your fluids
Jun 5, 2008 | 04:41 PM
Sounds like a Speed Sensor issue. Is the speedometer working correctly?
Jun 5, 2008 | 04:44 PM
while its running. the truck is drive able just cant go above 25 with out blowing it up in first gear.. ya know?
Jun 5, 2008 | 04:45 PM
from what i know the speedometer is workin right,,
Jun 5, 2008 | 04:46 PM
i lied the speed ometer does not work my dad just told me
Jun 5, 2008 | 04:47 PM
sounds like a tranny problem, can you turn the vehicle off or shift it into other gears, if yes your tranny is toast!
Jun 5, 2008 | 04:49 PM
like turn the key of while its still in gear?
Jun 5, 2008 | 04:51 PM
and the fluids are ok he informed me
no.................can you put it into park, then turn it off, or is it stuck in gear now!
Jun 5, 2008 | 04:52 PM
no it goes in park. just while drivin down the road it doesn't like tell itself to shift to second or third
Jun 5, 2008 | 04:53 PM
its your tranny then, sorry
Jun 5, 2008 | 04:55 PM
would that be tied into the anti lock brake light being on
Jun 5, 2008 | 05:00 PM
no, unless your brakes are locked up for some reason, but you'd smell that, the abs would have nothing to do with your truck not wanting to shift into higher gears, probably a sensor to your abs is loose or got bumped
Jun 5, 2008 | 05:23 PM
get some codes pulled...I can still see this as being that speed sensor or could be indicative of tranny problems. The codes will tell us which direction (or in my case it was both).
