another 12v conversion question
Old Jun 5, 2008 | 12:50 PM
newblder's Avatar
newblder
I'm planning on doing the conversion on my truck soon and am wondering if the conversion will require new switches for the lights, ignition, starter button, ect. Can anyone give me any insite on this stuff?
Old Jun 5, 2008 | 01:02 PM
bobj49f2's Avatar
bobj49f2
Your 6 volt components, swithes and wires will work fine. The 12 volt system draws less amperage than the 6 volt system, your 6 volt wiring is basically twice as heavy as a 12 volt system. As for lights, you can easily change out all of your lights to 12 volt bulbs but for your heater motor and gauges, you will have to use a drop resistors before each item so you don't over power them and blow them out. Your starter will be alright as long as you don't crank on it for long periods of time, it wouldn't hold up on 6 volt if you cranked on it for a long time. As for the ignition system, you should also use a heavy duty drop resistor before your coil, you may also be able to find a 12 volt replacement.
Splatts
134
Jun 10, 2013 11:53 AM
effie_man
Apr 5, 2011 11:07 PM
jrandol
Engine Swaps
Oct 5, 2009 04:10 PM
simply_peter
Jan 20, 2009 11:14 PM
