headlight wiring, relays
Old Jun 5, 2008 | 10:42 AM
sdetweil's Avatar
sdetweil
got it.. never had any problem with the alternator on my daughters 87 Stang.
and had one of those Taurus dual speed electric fans on there that sucked power like it was goin out of style
(45 amps to run a fan!!)
Sam
Old May 25, 2011 | 06:27 AM
53pickemuptruck's Avatar
53pickemuptruck
I'm going to use relays on mine.Got a RF express kit and they recommend relays with halogen lights .Supposed to make em brighter I think.
Old May 25, 2011 | 07:21 AM
sdetweil's Avatar
sdetweil
Originally Posted by 49fordpickumup
Sam, I lived in Houston for almost 20 years. My son had a HO mustang in the eightys having a alternator down low in the steering pump area. When it rained, the under passes flooded and shorted out the alt ($350.00). The relays we are talking about have one side direct to the battery. If it shorts out, the truck dies and flooding/loss begins. I understand the clean look. I just wanted you to be aware of potential problems. Have a great day,Chuck
thanks, all my relays for these functions are waterproof to prevent the problems u mention
Sam
Old May 25, 2011 | 08:15 AM
jniolon's Avatar
jniolon
old and in the way
Sam
+1 for relays... it's a little trouble to do it and it will make a difference in voltage at the bulb. I plan on relays for all hi-amp circuits... lights, cooling fan, etc. good advise on using identical relays for troubleshooting purpose..and the relay sockets also... any electronic supply store including Radio shack has them... but try to find brand name instead of chinese like RS sells. You might also want to look at circuit breaker instead of fuse in headlight circuit... they will reset automatically when they cool and you won't be stranded on a dark road.
I know you understand all the electrical stuff... but I'll add this here to help those that think relays are black magic..
USING RELAYS TO CONTROL
later,
John
Old May 25, 2011 | 08:35 AM
hellfirejim's Avatar
hellfirejim
When I re-wired my ride I used relays for the usual suspects but I increased the wire size for the power side. As an example the headlights are bright and work well.
But of course without good grounds it doesn't matter what you use.....
jim
Old May 25, 2011 | 08:46 AM
sdetweil's Avatar
sdetweil
Originally Posted by jniolon
Sam
later,
John
I used specially sealed relays. search "High Current Sealed Relay Kit"
Let me google that for you
sam
Old May 25, 2011 | 08:49 AM
BACAGrizz's Avatar
BACAGrizz
I was so impressed by MAD Electrical I bought the big kit. I am looking at Rebel wiring also for my truck.
I vote in favor of relays too. Nice looking water resistant unit there. Do they work well?
Old May 25, 2011 | 08:57 AM
sdetweil's Avatar
sdetweil
well, I haven't been in any water,(the mistress doesn't do water based things!) but the relays work perfectly!
The relay body is ceramic and plastic sealed, the rubber gasket seals the connection, and the base pins are sealed access to with a rubber boot the wires go thru.
the headlight relays are behind the drivers side headlight bucket
the fan/fuel pump/air pump relays are located at their device.
the normal harness control wire controls the relay.
I have a 6 way fan out connector (autozone I think, each separately fused) down below the battery on the inner fender with separate feed lines to each relay. (fan and headlights closest draw demand, and biggest feed wire)
Sam
Old May 25, 2011 | 09:08 AM
hellfirejim
sam
Doesn't this kit require a special tool for the pins?? If so do you know how much???
jim
Old May 25, 2011 | 10:12 AM
low54's Avatar
low54
Sam,
Not to get to far off topic, but you mentioned using a different ignition switch...when I wire my truck can't I just use the stock one?...I'm running rebel wire...also i'm not familiar with relays...not very savey w/ electrical..
Old May 25, 2011 | 06:11 PM
rhopper's Avatar
rhopper
I used three relays, two for the lights, high and low beam, and one for the fan. All are mounted on the inner fenders, and are visible. I wasn't as concerned with hiding the wires as you are, I just tried to make them neat. I'm currently (hah!) using a stock sealed beam but plan on upgrading some day so I installed the relays now. All were pulled from late model GM cars in the junkyard. Nice sealed units with mounting brackets. My American Autowire kit had a power feed for the fan, but the instructions say it's just to power the relay. I read the same MAD electrical website that several others did, I just got my parts cheaper. BTW, I ran a small dash switch to the fan relay so I can over ride the temp switch if needed. -Rusty.
Old May 25, 2011 | 07:30 PM
sdetweil's Avatar
sdetweil
jim
Nah, I just use a pair of needle nose. But I solder and shrink-wrap every connection.
Sam
Old May 25, 2011 | 07:32 PM
  #28
sdetweil's Avatar
sdetweil
Originally Posted by low54
Sam,
Sure, I wanted a fancy one.
Just have the headlight wire control the relay instead of lighting the bulb.
Sam
Tilleyman
Feb 12, 2016 05:48 PM
SuperDutyScaler
Sep 6, 2014 12:21 AM
5280
Jul 26, 2014 02:29 PM
Country_boy_2007
Feb 20, 2014 12:20 AM
Joe T.
Nov 8, 2011 05:29 AM
