CB Mounting in a '91
Thanks.
I ended up mounting it to the Flip down ash Tray, Only Because i use the tray to store stuff and i use the Sig Lighter for different things. The little Problem is the weight of the CB wont allow the Flip down compartment to stay shut but i dont see the need to close it anyway.
Thanks Again.
i dont smoke, and nobody else smokes when they ride in my truck, so it isnt a problem, but i have a fullsize radio, so the shifter about hits it (5 speed)
edit: mines a '92
Even if you mount it somewhere else, try the mic holder and see if it works behind your trim piece. It is a convienient location for it so you don't have to lean over to get the mic when you need it. I have also seen the hooks you could put on the back of the mics to hang them on the rear view if the cord is long enough. Most of the more expensive mics come with longer cords than the mics that usually come with the CBs.
Hope this helps.
May i ask you what antenna your using? I only have a 4ft Fiberglass right now but am looking into getting a 5000 Trucker someday.
Later
>little compact thing isnt it??
>Trucker someday.
>Later
I have a 5' Firestick (fiberglass) antenna mounted on a homemade mount. I heated and twisted & bent a piece of steel and mounted it above the tailight, in the crack where the tailgate closes. The bracket is L shaped and it is screwed to the truck above where the cables hold the tailgate. Kind of hard to explain.
A wilson or a K40 would probably work better but I still do go through the bank drive thru and I have seen them knocked off of bigger trucks. That antenna puts out all I need and I have seen many like it mounted to the antennas of 18 whlrs and such. It has an adjustment **** on top to set the SWRs.
I have had that little CB since 96 and it has been great. I got it tuned up by a local CB shop and it really puts out a strong signal. Not too bad for a reasonably cheap CB and doesn't take up nearly as much room. I'll try to get some pictures on here this weekend.
First, i have done a couple mounts above the gas pedal, but i don't recommend them as they can be a severe hazard in a collision, and if yer a big guy you won't fit with it too well.
I put a cb just to the right of the ashtray in my friend's '88 f-150. it's a good solid spot but it puts the cb kinda far away.
As far as antennas go, the best places for mounting are either on the fender with an L-bracket, or on the roof. the reason for that being antennas require a ground plane (metal surface fairly level with the base) for best operation. Mounting on the top of your box or the top of a fibreglass canopy does not provide a good ground plane.
Fibreglass antennas are fine, althought i sometimes find that the type with a coil at the bottom and a steel whip perform and look a bit better.
anyway, that's my ten cents. if there's any other questions drop a line in this thread.
>of installations into a lot of vehicles. I'll throw you a
>few pointers:
>well.
>far away.
The uniden is very compact which is why I was able to put it there. If it weren't then it would have never fit there due to the 4x4 shifter. I am 6'3" and I don't have any trouble with it being in the way. However, I never thought about it being a hazard in a collision. I have had a dashboard nearly end up in my lap and a cb wouldn't have helped that impact any. That's a very good point! I never thought of that.
I did mount my external speaker on the right of the ashtray where you were talking about.
I still hope to get some pictures on here if I can remeber to borrow my sisters digital camera.
