install for EGT sensor
Old Jun 1, 2008 | 11:16 PM
trayder's Avatar
trayder
Does anyone know the link to the installation guide for installing the pyrometer in the exhaust manifold? There used to be a neat site with pictures and instructions such as idling while drilling and tapping. Thank You Trayder
Old Jun 1, 2008 | 11:51 PM
brickie's Avatar
brickie
http://www.itpdiesel.com/other/6.0L%...structions.pdf Try this
Old Jun 2, 2008 | 11:06 AM
tazo's Avatar
tazo
DieselManor - Installation Sheets
Here is another.
Old Jun 2, 2008 | 11:10 AM
3000 FPS's Avatar
3000 FPS
When I did mine I used thick grease on the drill and tap to try and capture the metal shavings. I then used a strong magnet to pull any remaining shaving from the hole. All went well with no problems.
Old Jun 2, 2008 | 02:59 PM
Kep4's Avatar
Kep4
Jäger
Originally Posted by tazo
Those are the instructions I used and they're very good.
I would not recommend running the engine while drilling the exhaust header. I used cutting oil, lots running down my arm, and shop vac'd the whole afterwards.
Make sure you're wearing eye protection! I wore a full mask since I didn't want any metal shavings twixt teeth and gums or in my nostrils.
Old Jun 2, 2008 | 03:05 PM
D.J's Avatar
D.J
i second that. i did the same thing
Old Jun 2, 2008 | 05:52 PM
w_huisman's Avatar
w_huisman
I second that too.
I wore a set of goggles, not just glasses, and a small piece of metal still managed to get under the goggles and into my eye. Lucky for me by the time I climbed out from under the truck and made it into the bathroom, the particle had found its own way to the inside corner of my eye without scratching my eye surface.
I did my best not to blink.
Old Jun 2, 2008 | 05:55 PM
OZX1's Avatar
OZX1
I did mine engine running, lots of heavy grease to hold the chips and even more patience while I stopped often to clean them away. The event was more emotionally traumatic than anything. I don't like being under running trucks!
Old Jun 2, 2008 | 07:08 PM
06F250XLTFX4's Avatar
06F250XLTFX4
I drill mine with out the engine running. a drill bit is made to bring the metal shaving out. I also didn't use grease or cutting oil because I wanted to be able to Vaccumn the fine metal particles out afterwards. All went well. There is so many way to do it. I don't think there is a "right way" you just have to do what you feel comfortable with
Old Jun 2, 2008 | 10:52 PM
tazo's Avatar
tazo
When I drilled mine I duct taped the the shop vac hose right next to the hole I was drilling. The shavings would be sucked right up. Same concept as my dust collector in my wood shop. I then vacuumed out the hole really good. I then started the truck just to make sure the was nothing inside and then I installed the pyro probe. I had no problems at all except for all the sweat rolling down my face worried that I would screw up the truck.
Old Jun 3, 2008 | 09:03 PM
trayder's Avatar
trayder
Trayder
Just got back and saw all of the great response to my question about installing EGT probe. Thanks to all of you. THANK YOU!!!
Jens
Dec 24, 2002 02:44 PM
abendx
Aug 16, 2002 08:21 PM
powerstroker250
Jul 12, 2002 01:42 AM
cyberbyrd
Garage & Workshop
May 17, 2002 03:22 AM
xaviar
Apr 18, 2001 12:55 AM
