I think it's the computer
Old Sep 18, 2009 | 12:42 AM
stractor's Avatar
stractor
Found the same type of burned cap on my 1990 computer. It caused no start conditions and really bad miss at idle ( is any idle at all) when cold or especially when the air was damp and rainy. I chased the condition for about a year, it showed no codes, and finally decided to open the computer and look for a loose or cold solder joint on a component. That is when I found the bad cap. I replaced the cap with the same value but a slightly higher voltage and so far(3 months) so good. It is back to its old reliable self.
Old Sep 20, 2009 | 12:04 PM
mary-kate's Avatar
mary-kate
That's awesome. I was going to do just that because electrolytic capacitors are super cheap. However, when mine blew it destroyed traces on the board; so mine was garbage anyway.
Old Sep 20, 2009 | 11:41 PM
stractor's Avatar
stractor
You can rebuild the traces if the damage is not to widespread. Mine took out the traces also but I rebuilt them using solder and bits of wire from some spare new resistors in all that electrical junk I have been saving for years.
ajnilson
15
Jul 29, 2024 02:07 PM
kmrbriscoe
Jul 16, 2013 11:29 PM
volks
25
Feb 17, 2010 07:43 PM
striker_wvu
May 20, 2008 08:35 AM
90f1502wd302
Jan 9, 2008 08:20 AM
