4.9L engine stalls when ac engaged
Old Jun 1, 2008 | 10:33 AM
jfrankp2's Avatar
jfrankp2
1995 F150 with 4.9L. Starts and runs fine, but stalls when ac mode engaged (also in defrost mode). Changed electrical connector at ac compressor clutch, disconnected wiring to ac clutch - no success. Autoparts stores shows an ac relay, but owner's manual and Haynes repair manual do not give any help on if the relay exists or it's location (under hood, under dash). It's getting hot in Texas, any help would be appreciated.
Old Jun 1, 2008 | 12:11 PM
Motorhead351's Avatar
Motorhead351
What code(s) are you getting
Old Jun 1, 2008 | 02:03 PM
srercrcr's Avatar
srercrcr
The computer should be kicking up the idle speed like 100 rpm to compensate for the drag of the compressor on the engine. On carbed engines that was accomplished with an electrical olenoid just kickicg into the throttle lever, but with a computer I'm in the dark...sorry. Is your idle speed w/o air on a little low?
Old Jun 1, 2008 | 09:33 PM
jfrankp2's Avatar
jfrankp2
No Codes?
  1. Not getting a check engine light. Will stop by AutoZone to see if scanner picks up any codes set in computer?
Old Jun 2, 2008 | 11:44 AM
n9lhm's Avatar
n9lhm
Is the A/C compressor seized up? Can you turn it by hand?
Old Jun 2, 2008 | 11:46 AM
SOB Racing's Avatar
SOB Racing
Your A/C clutch may be bad?
Old Jun 2, 2008 | 03:20 PM
85e150's Avatar
85e150
If the ac works and no noise or high heat on the compressor, go back to idle control. As stated above, idle should be kicked up when ac/defrost goes on.
How is idle controlled on your vehicle? Any connections there? Anything traceable to the a/c unit?
Old Jun 2, 2008 | 06:43 PM
6CylBill's Avatar
6CylBill
Hey man, I don't have anything to add to help with your problem but I'm in Texas too and I wanted you to know I feel your pain. I work outside and I know it sucks. It's not even officially summer yet. =/
Old Jun 21, 2008 | 09:47 AM
jesterdog's Avatar
jesterdog
My 94 F-150 did the exact same thing back when it was under warranty thankfully, because it was a siezed up compressor. It would kill the engine when AC or Defrost was turned on. When driving down the road, I switched the AC on to check and the engine went into serious lug down mode and I immediately switched it back off.
tractorboy924
Jul 13, 2017 11:26 AM
FrankCZ
Jul 28, 2016 08:44 PM
Flatland6
Dec 9, 2015 05:53 PM
bulred
Modular V10 (6.8l)
Aug 29, 2015 05:28 AM
Soodude
Jul 18, 2011 07:47 AM
