Throttle Position Sensor: Anyone ever replaced one...?
Old May 31, 2008 | 07:19 PM
Bambu's Avatar
Bambu
Hi all, I guess this is the place I need to post....Gonna be changing out my tps on my '00 F250 PSD. Anything special I need to know or is it plug and play???
Thanks in advance!
Old May 31, 2008 | 07:46 PM
megawatt00's Avatar
megawatt00
Welcome to FTE. It is a real simple job shouldn't take any time at all/
Unplug electrical connector
Remove the bolts and remove the accelerator pedal and sensor assembly.
Installation
Follow the removal procedure in reverse order.
Old May 31, 2008 | 08:11 PM
Bambu's Avatar
Bambu
Thanks Jim! Just what I needed to hear. Pictures are always helpful, too! Much appreciated.
Dan
Old May 31, 2008 | 08:15 PM
megawatt00's Avatar
megawatt00
Your welcome Dan. I also read somewhere that these units are already precalibrated and there is no adjustment on them. Good luck with the replacement and please post back and let us know how you made out.
Old May 31, 2008 | 08:21 PM
servitrans's Avatar
servitrans
bambu, did you test the tps sensor first?
if you 100% sure is bad then disconect negative cabkle from battery, remover the 2 screw and just pull the sensor, is going to click sound, to installed just present the sensor and move it forward about 1/16 then pull back and screw it.
Old May 31, 2008 | 11:22 PM
Bambu's Avatar
Bambu
Servitrans, I'm not 100% sure it's bad but I've had throttle hesitations off and on since I bought the truck last Oct. and about 2 weeks ago, I had a real bad hesitation at an intersection, then it sputtered and the SES light came on. It ran rough on and off the rest of the way home and the SES never went out. I had a buddy hook up his OBD and it indicated the TPS was the culprit. He reset the SES and it hasn't come on since but I am still having periodic hestations and some surges so I figure the TPS needs replacing. I heard there was a way to reset the TPS somewhat like you suggested but was not sure how to do it. I'll give it a try and let you know.
P.S. Thanks for the Welcome to the site, Jim.
Dan
Old Jun 1, 2008 | 10:43 AM
lhud's Avatar
lhud
Sounds like a possible CPS acting up. Rough idle and a SES could also indicate issues with the UVH.
Really should pull some codes before proceeding with any part replacements.
Good luck,
Old Jun 6, 2008 | 07:06 PM
Bambu's Avatar
Bambu
Took 10 minutes to replace the tps (whole pedal assembly) and the issues are gone. Ihud, I hooked up my friends OBD and it indicated the tps was the issue before I ordered one. I had the cps replaced when I learned of the recall. Thanks to all who responded.
bcaughhorn
Aug 25, 2013 04:19 PM
brandon.edwards
Feb 14, 2013 04:25 PM
compaddict
Jan 19, 2013 03:05 PM
bnkrtstk
Nov 6, 2007 05:37 PM
krewat
Modular V10 (6.8l)
41
Nov 7, 2005 12:53 PM
