Which class 3 front end receiver hitch
Old May 29, 2008 | 05:46 PM
squaredancer's Avatar
squaredancer
I'm looking to put my genset up front. no room in the back and the bumper on the 5er is not all that sturdy. I've found three different brands, all similar, except; Hidden Hitch says I can't do it because I might have a blocker beam, Curt offers the product for either with or without a blocker beqam, and ACI makes no mention of a blocker beam. So what's a blocker beam ?
Old May 29, 2008 | 05:53 PM
ron's power stroke's Avatar
ron's power stroke
i have a 9,000 LB draw tight i like a lot..need to take the bumper off to put it on..
Old May 29, 2008 | 05:55 PM
ron's power stroke
Edit...Damn double post.....
Old May 29, 2008 | 06:19 PM
jmcder53's Avatar
jmcder53
do front hitches make it hard to get to parts of the engine? it looks like you had to cut through part of a grill on your bumper, any problems with that?
Old May 29, 2008 | 06:38 PM
ron's power stroke
that's a custom screen I made with heavy 1/8 inch vinyl ..we use a lot of sand up here in the winters on the road. there trying to save on salt.. ..stone's would get kicked up and they hit my IC a couple times and took out my windshield,,so I put that screen in there..your truck wont have it..but i does have the front plate holder there..so you will need to find a place for that..you can see what i did to mine..the hitch comes with brackets and every thing to put it on..pull the front bumper off..swap out the brackets..put the hitch on..put bumper back on..make sure the bumper is strait..tighten bolts..
Old May 29, 2008 | 06:39 PM
ron's power stroke
here is a pic from further back..
Old May 29, 2008 | 06:47 PM
jmcder53's Avatar
jmcder53
i'm guessing the bumper is in excess of 100 pounds closer to 2.
Old May 29, 2008 | 06:54 PM
ron's power stroke
not sure what the front bumper can hold..but the hitch will hold 500LB and pull 9,000 lb
or if you mean the waight..its less then 50lb..not that heavy...
Old May 29, 2008 | 07:14 PM
ron's power stroke
rchouser
Jul 17, 2020 09:44 AM
shadows4
Aug 21, 2014 08:56 PM
afonda
Apr 8, 2013 08:10 PM
tvman44
May 27, 2011 11:46 AM
