Boss, how about Erson's ? They make setup, and seem resonably priced as compared to others. DF
Thanks I will check them out. Do you know if they make a setup for the medium riser? as diff from normal 390-428 as shafts are longer and stands are wider..
Yep they do. They list #918503 as the set for Edel, MR and TP heads. $680.
thanks a bunch! I will check it out..
spoke to tech assistance! probably will go with those rockers and thanks for info. Had a difficult time to try to find number for them and even the tech could not find them on site..... may have them build me a custom roller cam too. about all I need to finish engine
I run DOVE HD roller set up on my race car. Pretty pricey these days(north of $1100 I think), but complete with stands(with special end stands), shafts, rockers, spacers, studs. Ready to bolt on. They run rock solid and I never have to adjust them thru the year.
thanks,
spoke with steve t at erson again today and theirs list for 760 and in stock, the 680.00 price given by another member is a great price. will also check on the DOVE HD's
I may be going the BOss 9 route now and will know in a couple weeks before I make a decision on the custom cam etc. either way will need the rockers to complete the engine even with the solid flat tappet vs solid roller
