Check engine light!
Old May 28, 2008 | 11:20 PM
Dre82s's Avatar
Dre82s
Check engine light!
My check engine light blinks as i drive, it doe not stay on, how do i go about figuring out what is the code that is shooting? and how do i do the timing on my '88 F-250, what connector do I have to disconect or connect?
Old May 29, 2008 | 04:56 AM
EPNCSU2006's Avatar
EPNCSU2006
Here is a link that shows how to pull the codes: EEC IV Self Test hookup . You can leave out the voltmeter/test light and simply watch the check engine light blink.
To set the timing correctly, you need to pull what's called the SPOUT (SPark OUTput) connector, which will disable the computer advance. The SPOUT connector on your 88 will be near the distributor.
kennybrown
Nov 7, 2012 06:40 PM
donbrown
May 1, 2010 12:21 AM
Stangfire
1997 - 2003 F150
Apr 29, 2008 08:51 AM
fwhitsell
May 19, 2006 08:16 AM
swampler
Modular V8 (4.6L, 5.4L)
Oct 18, 2004 11:50 AM
