water pump leaking?
Old May 28, 2008 | 07:25 AM
gofast51004's Avatar
gofast51004
Originally Posted by clintbonnie
The weep hole in on the bottom side of the pump housing, just behind the pulley.. The hole is just to let the coolant escape if the bearing goes bad and the coolant goes past the bearing seal.. The weep hole is not a repairable item.. If you are loosing coolant from the weep hole it is time to change the pump..
10-4, Thanks, I'll take another, closer look tonight to see if I can see where it is dripping from.
GormGorm
13
Dec 24, 2014 11:28 PM
Jumbo131
6.7L Power Stroke Diesel
Mar 25, 2014 07:46 PM
cgoservices
Feb 1, 2013 10:58 PM
bozo4ford
Sep 28, 2010 09:09 PM
viperbluelx
Jan 11, 2008 06:58 AM
