hi all
i would like to convert lockup converter to a manually controlled .i want install a manual switch with control led to bypass the computer .can you give me schematics for procedure.
my truck is f350 2wd dually 7.3 idi turbo 1994 with e4od.
thank's for all
hi all
no i just want lock it.I am certain it's to close.
just to close when I want.i have a code 62 and 23 when the road goes up and when i must change speed 1-2,2-3 good ,3-2 .....limp mode. rpm sensor new,vss new,tps new,shift selector new ,pack solenoid new..but if i accelerate slowly no limp mode. I suppose that the converter sticks badly or this takes off.
thank's for yr help
To find the remove the trans harness conector from the fire wall it will be the one closest to the fenderwell and find the purple with yellow tracer wire.
I don't know if this will help your problem though.
hi all
thank's for all
If your TC is bad go to "monster transmission & performance" 800-708-0087. the prices look good....good luck...S.P.
