E40D lockup Modification
Old May 26, 2008 | 06:03 AM
frederic.c01's Avatar
frederic.c01
hi all
i would like to convert lockup converter to a manually controlled .i want install a manual switch with control led to bypass the computer .can you give me schematics for procedure.
my truck is f350 2wd dually 7.3 idi turbo 1994 with e4od.
thank's for all
Old May 29, 2008 | 11:36 PM
ford trans tech's Avatar
ford trans tech
dont do it
the processor wont like it and always enter failure mode management
Old May 30, 2008 | 12:33 AM
George D.'s Avatar
George D.
Are you wanting compleet controll or just to be able to lock it?
Old May 30, 2008 | 06:24 AM
frederic.c01
Thumbs up
hi all
no i just want lock it.I am certain it's to close.
just to close when I want.i have a code 62 and 23 when the road goes up and when i must change speed 1-2,2-3 good ,3-2 .....limp mode. rpm sensor new,vss new,tps new,shift selector new ,pack solenoid new..but if i accelerate slowly no limp mode. I suppose that the converter sticks badly or this takes off.
thank's for yr help
Old May 30, 2008 | 10:29 PM
George D.'s Avatar
George D.
This is how i did it.
This is how other people have done it.
http://www.dieselinnovations.com/techfiles/tclockup.pdf
Torque Convertor Lock-up mod
To find the remove the trans harness conector from the fire wall it will be the one closest to the fenderwell and find the purple with yellow tracer wire.
I don't know if this will help your problem though.
Old May 31, 2008 | 10:09 PM
ford trans tech
you have a converter that is slipping under load
manually locking it wont stop it from slipping
Old May 31, 2008 | 10:32 PM
S.P.'s Avatar
S.P.
Wink
Originally Posted by frederic.c01
hi all
thank's for all
If your TC is bad go to "monster transmission & performance" 800-708-0087. the prices look good....good luck...S.P.
AeroZona
Aerostar
27
Nov 21, 2016 09:19 PM
Willz74
Nov 20, 2015 09:29 PM
emoe
Feb 9, 2005 01:05 PM
cbell_hs
1983 - 2012 Ranger & B-Series
Dec 15, 2003 09:12 PM
1972 Ford Thunderbird 429 V8
Oct 6, 2002 11:23 AM
