Break away switch ?
Old May 25, 2008 | 02:37 PM
Umaxman's Avatar
Umaxman
Break away switch ?
Ok here is my problem, The brakes on my trailer work fine but the break away switch doesn't work.
If I pull the pin it should lock the brakes on right?
So I tried a new switch and still the same thing Is this the proper way to test them or is there a different way and what else could I look at?
Old May 25, 2008 | 02:59 PM
Steina's Avatar
Steina
CO River Rat
Sounds like a wiring problem - do you have 12vdc to the switch? BTW, make sure your trailer is never plugged into the TV when you test like this; some controllers don't take kindly to reverse voltage and will fry.
Steve
Old May 25, 2008 | 03:04 PM
Umaxman's Avatar
Umaxman
No TV hooked to the trailer just the trailer battery, Should there be 12 volts on the wire to the break away and then when pulled it allows the 12v to complete the circuit? the wires on the switch should be live?
I hate wiring problems ........
Where should I start?
Old May 25, 2008 | 03:08 PM
Steina's Avatar
Steina
CO River Rat
Did you check the breakaway battery for 12vdc? One of the wires to the switch should be hot all the time.
Steve
Old May 25, 2008 | 09:17 PM
Umaxman's Avatar
Umaxman
I will have to have another look but I don't believe there is power.
One wire can be hooked directly to a live battery wire ? and the other one to the brake wire?
I found a diagram and it doesn't seem to match the way mine is wired.
If it is any help the trailer is a 21.5 ft fifth wheel
Old May 25, 2008 | 10:11 PM
mlb4966's Avatar
mlb4966
Sounds like Steina has it narrowed down. You should have power to the breakaway switch. When you pull out the "Pin" it completes the circuit and sends "juice" to the electric brakes.
Make your self a jumper with a piece of wire and some alligator clamps. Try to energize the switch and pull the pin and see what happens. You should then get power to your brakes. Good point on disconnecting sensetive electronics.
Have fun and enjoy. Isn't wiring a pain in the butt!
Old May 30, 2008 | 03:30 AM
Umaxman's Avatar
Umaxman
Thanks for the tips, as it turned out to be a broken end on the wire.
Old May 30, 2008 | 10:09 AM
Steina's Avatar
Steina
CO River Rat
Glad to hear you got 'er fixed!
Steve
hwyhogg
15
Dec 8, 2014 08:15 PM
RV_Tech
All Things Towing
35
Oct 7, 2010 04:05 PM
whiteywhip
All Things Towing
Apr 13, 2009 07:00 PM
dchamberlain
All Things Towing
60
Dec 23, 2008 06:45 AM
broncofl
1966 - 1977 Early Broncos
Nov 23, 2004 12:35 PM
