Two-tone paint
Old May 24, 2008 | 05:56 PM
66f-100's Avatar
66f-100
Two-tone paint
My 66 f-100 originally came as a 2-tone black and white truck based on the paperwork I found in the glovebox. It doesn't appear to have ever had the chrome trim on the sides which normally separates the two colors (at least from what I can tell). Did they come this way?
Old May 25, 2008 | 06:56 AM
jowilker's Avatar
jowilker
Da Dummy will know for shore, but I don't recall black & white tu-tone paint schemes. AFAIK all tu-tone paint came with the side trim.
This one could get interesting.
John
Old May 25, 2008 | 07:50 AM
66f-100's Avatar
66f-100
I looked at it a little more closely today and I see that someone has filled the holes where the trim used to be. The original paperwork is in the glovebox, and it clearly says black and white paint. I will post the door tag data later and see if someone can decode it.
Old May 25, 2008 | 03:40 PM
66f-100's Avatar
66f-100
OK, here is the data plate info:
Warranty # Color Model Body Trans Axle
F10AN872880 blank F100 D81 G 09
Max GVW Cert Net HP DSO
05000 129@4000 252574
If someone would be kind enough to decode this info for me I would appreciate it. The truck has a 352-2v motor with what I believe is a C-O-M.
129 hp sounds a little low for a 352.
Thanks,
Mark
p.s. the original paperwork also said 1,250# springs. What would the stock springs have been?
Old May 26, 2008 | 01:26 AM
camperspecial65's Avatar
camperspecial65
the VIN is as follows...
F10 = F series 1/2 ton 2wd truck
A = 240 6 cyl engine, 129 hp, 1 bbl carb.
N = Norfolk, Va assy.
The lack of a color code based on what you typed tells me it was a special ordered color combo..and the 6 digit DSO...the last 4 are the order number as it is indeed a specially ordered truck. The DSO (25)is Richmond, Va where it was ordered through.
872880 = very early June 66 build date
G is a C-O-M auto. trans
09 = 3:70 rear end gears, non locking
- cs65
Last edited by camperspecial65; May 26, 2008 at 01:34 AM. Reason: correcting DSO info..deleting some text
Old May 26, 2008 | 01:36 AM
camperspecial65
D is a beige interior trim...Medium Beige crush vinyl and medium beige cody pattern woven plastic
- cs65
Old May 26, 2008 | 06:40 AM
66f-100's Avatar
66f-100
- cs65
Thanks for the info cs65. That clears it up a bit. Interestingly enough though, the original paperwork stated that the seats were red.
Mark
Old May 26, 2008 | 12:07 PM
jowilker's Avatar
jowilker
Just had a thought, maybe the original paperwork is for a different truck.
John
Old May 26, 2008 | 12:54 PM
gritsngumbo's Avatar
gritsngumbo
Or maybe the door tag has been changed. What color is the truck and interior now?
Old May 26, 2008 | 02:07 PM
66f-100's Avatar
66f-100
The door tag matches the tag attached to the firewall. The truck is all white now. I can see some blue paint underneath the white in a couple of places on the front fenders, so I assume it was painted blue at some point. I also see black paint underneath where it has flaked off, so I believe it was black and white originally like the paperwork says. I pulled back the seat cover, and the upholstery is blue. I guess that was changed when the truck was painted blue. I guess a lot can happen in 42 years.
Old May 26, 2008 | 02:46 PM
camperspecial65
These trucks did not have any kind of tag attached to the firewall....the VIN is stamped on the top surface of the right frame rail. When you are standing on the side of the truck, its location is about parallel with the alternator.
The VIN is bracketed by astericks on either end and the numbers/letters are about 1/4" tall...a wirebrush and/or putty knife should help you find it in short order to confirm.
The only other tags ive ever heard of under the hood on these trucks were attached to the carburetor, the engine assembly and the steering box.
- cs65
Old May 26, 2008 | 04:20 PM
66f-100's Avatar
66f-100
I am at work right now, but I am certain I saw a tag on the firewall and I cross checked the VIN to make sure they were the same. I will verify the exact location when I get home tomorrow morning.
Old May 26, 2008 | 04:24 PM
66f-100's Avatar
66f-100
Could it be a Buck Tag?
Old May 26, 2008 | 09:30 PM
Customcab's Avatar
Customcab
It could be a temporary tag; these trucks had a temp tag given to the owner from the dealership I beleive; and maybe the 1st owner place it on the firewall.
I got a two tone black & white 65 in my gallery; it was orginially a blue & white, but I like the black & white better. I'm shock that John mention it wasn't an option color. I like it the best; seen too many red's blue & green two toner's. Love my black & white gets alot of complements as well.
Old May 27, 2008 | 05:41 AM
jowilker's Avatar
jowilker
Didn't say there weren't any, said I didn't recall any. I have seen a tag pinned to the top of the firewall on some, but not on all. It didn't seem to bother the running of the truck so I didn't think much about it.
Black trucks have really picked up speed in the last 10-15 years.
John
