Bronco II Ford Bronco II
rewiring a a4ld
Old Jun 6, 2008 | 06:28 PM
bronco2man's Avatar
bronco2man
rewiring a a4ld
changed from a 5 speed manual to an a4ld, trying to figure out the wiring for neutral start switch
Old Jun 11, 2008 | 07:10 PM
danr1's Avatar
danr1
Jumper the clutch petal switch or connect it to the safety switch on the auto trans neutral safety switch.
You'll also need the EEC from a B2 with a automatic transmission. Then need to run two wires to the solenoids in the tranny to the appropriate pins (IIRC 52 and 53) at the EEC so it will shift to OD and so the TC clutch will lock up.
The wiring harness in a body that had a factory manual trans will not have those wires installed.
Adding the two wires is much easier than changing the whole harness.
Just did it myself so if you need more exact info let me know.
Old Jun 12, 2008 | 05:28 PM
bronco2man's Avatar
bronco2man
thanks for the info, have the reverse lights working, still have 3 wires that i dont what they go to, i think 2 are for starting in p and n only,, not sure what third wire is doe?
r/lb, r/w, y
Old Jun 12, 2008 | 06:03 PM
danr1's Avatar
danr1
r/lb
Ignition (start), Clutch interlock switch, TFI module, starter relay (manual trans)
r/w
Turn/stop/hazard lamps
y
Rear window wiper/washer defrost off 18g fuse link (fuse link is black)
Old Jun 12, 2008 | 06:05 PM
bronco2man's Avatar
bronco2man
these wires are on the neutral safety switch
Old Jun 12, 2008 | 06:30 PM
danr1's Avatar
danr1
<i>these wires are on the neutral safety switch</i>
Are you saying all three of the wires you listed are on the neutral safety switch?
Only 2 wires on that switch and they are the same wire, a switched loop.
Old Jun 12, 2008 | 06:37 PM
bronco2man's Avatar
bronco2man
had 5 wires coming off the a4ld tranny for neutral safety switch, 2 are the reverse lights
Old Jun 12, 2008 | 06:55 PM
danr1's Avatar
danr1
I have found this book to be wrong a few times so have to take it with a grain of salt, maybe this will help.
Old Jun 12, 2008 | 07:02 PM
danr1's Avatar
danr1
Old Jun 12, 2008 | 07:33 PM
bronco2man's Avatar
bronco2man
my backup lights wire is blk/pnk
Old Jun 24, 2008 | 11:05 AM
bronco2man's Avatar
bronco2man
need a pig-tail for that solenoid, was told by the mechanic who is wiring it
Alex from GA
1983 - 2012 Ranger & B-Series
Mar 24, 2012 07:50 PM
BigLoo
Aerostar
Nov 14, 2011 03:27 PM
todd koebel
Bronco II
Dec 3, 2007 05:42 PM
kvb78
Apr 13, 2004 06:54 PM
