Temperature coolant sensor
Old May 22, 2008 | 04:02 PM
Aggie05's Avatar
Aggie05
Okay 92 2.3 ltr.
Coolant sensor on dash is at bottom and once running a while moves up a little but below the NORMAL markings. I see a sensor on one of the heater hoses, where should i look to get this fixed. It gets warm here in TX and i want to know how my truck is cooling or not cooling.
Thanks
Old May 22, 2008 | 10:25 PM
Aggie05's Avatar
Aggie05
BUmp for answers :P
Old May 23, 2008 | 07:31 AM
Powerkleen's Avatar
Powerkleen
From what I understand on the temp sensors...... the one at the outlet of the thermostat is the one that feeds information to the computer.........there is another on the driver side of the block just above (i think) the oil filter. The block sensor is the one that feeds information to the dash.
Anthony
Old May 23, 2008 | 08:12 AM
michigan66's Avatar
michigan66
Powerkleen is correct. Above the sensor on the block is the oil pressure switch on the head.
Old May 23, 2008 | 08:20 AM
Aggie05's Avatar
Aggie05
THere a way to test each one or just have to replace them both?
Old May 23, 2008 | 10:08 AM
Powerkleen's Avatar
Powerkleen
Do a search on here.... there is a way to ground the sensor to the block and i believe it should read HOT.
Old May 23, 2008 | 04:11 PM
michigan66's Avatar
michigan66
If my memory serves me correctly, disconnect the single wire from the sensor at the rear of the engine block, turn on the ignition, and ground the wire. If the gage is working properly, the needle will swing to the hot range. If that is the case, replace that sensor. The other sensor sends information to the computer.
Old May 23, 2008 | 10:42 PM
jimdandy's Avatar
jimdandy
The device that controls the gauge is not a sensor, it is called a sender. It serves a different purpose than a sensor. The above method for checking the gauge is correct. Disconnect the wire from the sender and the gauge should show no reading. Touch the wire from the sender to the engine block, or any ground and the gauge should move full hot. If it doesn't, the gauge itself or the wiring to it is faulty. The sender should read a couple hundred ohms to ground cold.
You problem could also be a thermostat that is stuck full open. This will not allow the water temp to come up. jd
Scndsin
Mississippi Chapter
55
Jul 31, 2014 11:49 AM
neuge
Bronco II
Apr 29, 2014 07:20 PM
BatteriesNotINCL
2004 - 2008 F150
Jan 18, 2009 11:52 PM
StephenA
Computer Chips & Tuners
Mar 19, 2007 02:11 PM
