Straight axle swap
Old May 21, 2008 | 08:19 PM
JoSHN's Avatar
JoSHN
Straight axle swap
So I want to look into the possibility of swapping out my TTB axle from my 93 f-250 for a straight axle.
I'm basically going to build up the axle until I'm ready to swap it out...if I do.
My questions here are:
1. Will I have issues with the leaf springs and shackles?
2. Will I have any issue with steering components? (i.e. will anything need to be changed to make sure it works?)
3. Will there be an issue with the driveshaft being too short or too long?
4. Is there any reason why this swap might be a bad idea?
Oh, and before I forget, you guys are awesome.
I'm extremely pleased that I found this forum. The knowledge that you guys have could almost put a haynes or a chiltons manual to shame.
Old May 21, 2008 | 11:22 PM
JoSHN's Avatar
JoSHN
Nevermind, I found the right forum to put this in.
Old May 23, 2008 | 06:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
JoSHN,
Welcome to FTE and the IDI diesel forum.
Direct swap, no problems.
Use the straight axle steering linkage.
My driveshaft worked on the straight axle just fine.
Straight axle ride is not quite as smooth, but tire wear is better.
Also I break and wear out less parts on the straight axle than I did on the TTB axle.
Old May 25, 2008 | 06:19 PM
JoSHN's Avatar
JoSHN
Well I am very glad to hear this.
I have never been the biggest fan of the TTB.
Even if it might make a smoother ride, It is not high on my list of great axles.
I also don't expect a smooth ride. I drive a 3/4ton. I bought it for it's capabilities, not it's comforts.
Now hopefully I can get every other issue fixed so I can get this swap done.
Damn e40d transmission!!
VAfarmboy
Jul 9, 2009 05:43 PM
JoSHN
May 22, 2008 08:52 PM
46stude
Oct 12, 2003 09:41 PM
paveslave
Apr 26, 2002 11:23 PM
