360?
Old May 20, 2008 | 12:38 PM
travisg96's Avatar
travisg96
360?
I purchased a parts truck with a 360in it. I didn't know ford made a 360. Is this a good motor or is it a lemon?
Old May 20, 2008 | 03:14 PM
85e150's Avatar
85e150
It's not a lemon, as they worked reliably and had no serious flaws that caused premature failure or constant issues.
What it is, though, is a 390 with a 352 crank. And the design results in a below deck piston height at TDC. That along with low compression, results in a fairly low power, high gas consumption engine. 360s were universally derided as gutless gas hogs when introduced. (performing just about the same as the 352 they replaced with respect to power and economy, but people expect more from a "new" engine...) Overall, fuel consumption is just about the same as the more powerful 390.
You can convert a 360 to a 390 or larger, correct the compression, cam, intake & headers and have 300+ hp without great effort. 400 hp can be had, just add money.
So don't put a chain on it and throw it overboard just yet. If it's a servicable block, it can be made respectable.
Old May 20, 2008 | 03:32 PM
travisg96's Avatar
travisg96
So what would I need to build it into a 390?
Old May 20, 2008 | 04:42 PM
85e150's Avatar
85e150
390 crank and rods. See the FE threads and read anything that says 360.
Old May 21, 2008 | 03:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
And 390 pistons.
Old May 21, 2008 | 03:58 PM
85e150's Avatar
85e150
The conversion postings suggest using the 360 piston, as it gives a good CR. There are a couple of threads with very specific info.
Old May 21, 2008 | 04:22 PM
krewat's Avatar
krewat
I've heard of a few doing that. Definitely check out the threads in the FE forum about it. Or post a new one
1956in1956
Sep 14, 2013 11:51 AM
Aaronmb
26
Jan 19, 2013 09:47 AM
DeepRoots
Nov 2, 2009 02:09 PM
ColodadoFordBoys
28
Jan 23, 2009 02:46 PM
460man
Nov 29, 2005 02:00 PM
