? about 360 - 390
Old Mar 29, 2008 | 12:42 PM
Aaronmb's Avatar
Aaronmb
? about 360 - 390
There is a local guy selling headers and valve covers off of a 390. My question is I have a 360, will the stuff he is selling fit on my 360?
Old Mar 29, 2008 | 12:55 PM
85e150's Avatar
85e150
It all fits. See if he'll toss in the crank, rods and pistons too.
Old Mar 29, 2008 | 12:59 PM
Aaronmb's Avatar
Aaronmb
I dont think he has all of that, but he does have a c6 tranny.
Old Mar 29, 2008 | 03:14 PM
waynaferd's Avatar
waynaferd
Every Ford/Edsel from the 352 to the 428 are all the same, save for the 427.
Old Mar 29, 2008 | 10:11 PM
mcdobson's Avatar
mcdobson
The bolt patern for the headers is different between car and truck 390's.
the bolt pattern for the truck 390 and your 360 is straight up and down, one obove the other.
Old Mar 30, 2008 | 04:54 AM
jowilker's Avatar
jowilker
The 360 was only used in trucks, but there is no difference between car and truck bolt patterns on FE series engines.
John
Old Mar 30, 2008 | 11:33 AM
19704X4F250's Avatar
19704X4F250
John
You may want to rethink that answer. Casting # C8AE-H has 2 different bolt hole patterns. The vertical 8 bolt pattern was on full size cars and trucks. 2 bolt holes vertical per each exhaust port. The fourteen bolt pattern was used on Mustangs, Courgars, Fairlanes, and Comets. Why? Those cars sometimes came with the rare factory cast iron headers. Therefore, those cars with the factory headers, will not accomadate aftermarket headers. They are missing the bottom 2 bolt holes in the center 2 ports. Hot Rod magazine October 2005 page 151
Old Mar 30, 2008 | 11:48 AM
jowilker's Avatar
jowilker
If we are going to quote a reference please use one worthy of quoting. The C8AE-8 is the same as C8AE-A, D3TE-D, & D5AE, which is a standard common 360, 390, 428 head.
GT heads use a different bolt pattern, but he didn't reference GT heads.
I stand by my original.
John
Old Mar 30, 2008 | 12:22 PM
19704X4F250
John
Wow! Hot Rod is not worthy of quoting? A magazine that has been in existence since the mid 50's! I guess you need to set them straight huh?
You said there was no difference in car & truck heads, but there is as far as exhaust bolt pattern. Are C8AE-H just GT heads with 2 different bolt patterns? Not according to the article. They are common 68-71 heads on 360, 390, and 428's, including the 68 390/265 or 315 hp, the 68 428/340 hp. and the 69 390/265 or 280 hp. Let's not forget that some larger FE's were swapped into these trucks just for the fun of it.
Old Mar 30, 2008 | 06:24 PM
gezn2's Avatar
gezn2
John
Let's not forget the near-mythical 1959/1960 Edsel 360, a few of which also slipped out as Police Interceptor motors
IIRC there are some differences in wrist-pin heights and/or rod-length to yield a much 'hotter' engine than the later truck 360
Others have brought up possible exhaust manifold issues, there's been enough years gone by that some swapping might have happened on either end, so an 'eyeball' check might be a good idea
Old Mar 30, 2008 | 06:46 PM
jowilker's Avatar
jowilker
You're probably not going to like this but the Edsel was introduced in 58 and that engine that you refer to was IDed as a 361, different from the destroked 390/360 truck engine. This info comes from Steve Christ, How to Rebuild your Big-Block Ford, and is regarded as gospel by many readers here.
This info is easily verified.
John
Old Mar 30, 2008 | 07:39 PM
mcdobson's Avatar
mcdobson
I don't care if you are quoting Christ or GOD himself, go look at a Fairlane or a Mustang with a FE motor and then tell me the bolt patterns are the same.
Old Mar 30, 2008 | 07:44 PM
waynaferd's Avatar
waynaferd
I thought the only difference for the 361 and 391's was they have steel cranks and were for heavy truck apps.
Old Mar 30, 2008 | 07:55 PM
gezn2's Avatar
gezn2
John
I don't have a dog in that fight, that's why I included 'smilies' and an If I Recall Correctly....
The OP *would* be smart to verify which exhaust patterns he's dealing with before laying down cash, swapping happens, especially when folks like us get involved
Old Mar 30, 2008 | 08:03 PM
19704X4F250
John
You can stand by your original all you want ....but you really stand CORRECTED! When someone asks a question, you can't give a pat answer anymore. Such as "Yeah it will fit." Too many varibles. Who knows what has been swapped. But we can say "This is what to look for." For the OP the engine may have been replaced with something more potent. I have seen it done. A racer retires, sells the car minus the engine. Keeps the engine for a few years, then decides to put it in his parts chaser. Forgets it is in there or doesn't care, and sells the heap to the kid down the block. Let's help these newbies a little better shall we?
