4x4 low switch engaged
Old May 20, 2008 | 12:17 PM
MarkZ's Avatar
MarkZ
Ok here goes. I had my truck cleaned and didn't notice the selector switch was flipped to 4x4 low. I don't know how far I drove but safe to say 50 miles and hitting 75, 80 MPH. The wheels were not locked in. I parked it after checking that it would still lock and unlock and looked for fluid leaks. All seems fine but what do I do now to make sure all is good...fluid drain through a screen looking for chuncks (hopefully not) and if this comes out ok what next? You are all great on this forum and have learned tons, thanks.
Old May 20, 2008 | 12:29 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You can't go 70-80 mph in 4x4 low. The thing is, if you didn't put it in N with the brake on then turn it to 4x4 low, it would not go in low. It stayed in high. I don't think you hurt anything. It only went to high, not low.
Believe me, if it was in low you would know it.
Old May 20, 2008 | 12:42 PM
MarkZ's Avatar
MarkZ
Thanks, thats the kind of answer I was praying for. How would I know if the hubs weren't locked in. Would I actually feel the front differential working.
Old May 20, 2008 | 01:16 PM
miller_feed
If you would make a sharp turn the front would bind up. When was the last time you used 4x4?
Old May 20, 2008 | 01:45 PM
MarkZ's Avatar
MarkZ
Sorry, I worded that last reply wrong. I know that the hubs were not locked in so thats why I was wondering how I would feel it. I know that the front drive line was engaged and the switch was on 4x4 low but it couldn't have been running in low with the tranny in drive, correct.
Old May 20, 2008 | 01:55 PM
mudmaker's Avatar
mudmaker
Put it in 4low once and see for yourself the difference. It is much lower gearing and therefore very noticeable.
Old May 20, 2008 | 02:09 PM
miller_feed
Like Marc said. Put truck in N step on brake, turn switch to 4x4 low, wait up to 20 seconds. If don't engage put in R, back a little and stop, put in N while holding the brake pedal. Tell us what happens.
Old May 20, 2008 | 02:13 PM
MarkZ's Avatar
MarkZ
Ok, thanks for the help...at work, will try after I get home.
vwovw
Nov 11, 2014 07:50 AM
grey2112
Sep 8, 2013 09:37 AM
Dixie.Ford.
2004 - 2008 F150
Mar 19, 2013 05:46 PM
Bad 674x4
Mar 4, 2013 08:17 AM
SLAMMIN 22
Mar 29, 2010 12:47 AM
